Multiple Encoders In one Midi Controller
Greetings. I am a new Arduino user and am using the mega board. I am trying to create a midi controller with 4 buttons, 1 fader/poteniometer and 12 Rotary Encoders. I have been able to set up the fader and the buttons without any issues and they upload fine and work. I have been playing around with the code but I cannot get it to work with more than one encoder. How can I fix this code to be able to add the 12 encoders and have the code upload successfully to the Arduino? The code is pasted below.
#include <Control_Surface.h> // Include the Control Surface library
// Instantiate a MIDI over USB interface.
HairlessMIDI_Interface midi;
// Instantiate a CCAbsoluteEncoder object
CCAbsoluteEncoder enc {
{9, 10}, // pins
MIDI_CC::Pan // MIDI address (CC number + optional channel)
// optional multiplier if the control isn't fast enough
using namespace MIDI_Notes;
// Instantiate the momentary push buttons that send out MIDI Note events.
NoteButton buttons[ ] = {
{A5, note(C, 4)}, // digital input pin, note number
{A6, note(Db, 4)},
{A7, note(D, 4)},
{A8, note(B, 4)},
// If you want to set the channel specifically, you can use:
// {2, {note(C, 4), CHANNEL_1}},
// Instantiate a CCPotentiometer object
CCPotentiometer potentiometer {
A7, // Analog pin connected to potentiometer
{MIDI_CC::Channel_Volume, CHANNEL_1}, // Channel volume of channel 1
Control_Surface.begin(); // Initialize Control Surface
Control_Surface.loop(); // Update the Control Surface
}Preformatted text
Your code only has one encoder.
Post the problem code, entire, in code tags please, and also the errors you get (verbatim, entire, code tags).
Remember if we can't reproduce your problem, its not going to be easy to fault-find.
