Multiple errors in my code [Solved]
My code:
#include <SoftwareSerial.h>
SoftwareSerial myUART(0, 1);
#include <Adafruit_TFTLCD.h>
#include <Adafruit_GFX.h>
#include <TouchScreen.h>
#define LCD_CS A5
#define LCD_CD A4
#define LCD_WR A7
#define LCD_RD A8
#define LCD_RESET A6
#define BLACK    0x0000
#define BLUE     0x001F
#define RED      0xF800
#define GREEN    0x07E0
#define CYAN     0x07FF
#define MAGENTA  0xF81F
#define YELLOW   0xFFE0
#define WHITE    0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
  myUART.begin(115200);
  tft.reset();
  uint16_t identifier = tft.readID();
  tft.begin(identifier);
  tft.setRotation(0);
  tft.fillScreen(WHITE);
  tft.setCursor(30,40); //Tal vez haya que cambiar la posicion
  tft.setTextColor(BLACK);
  tft.setTextSize(2);
  tft.print("CONTROLADOR REYMI");
 tft.setCursor(5,120);
 tft.setTextSize(1);
 tft.print("Corriente:");
 tft.setCursor(5,100);
 tft.setTextSize(1);
 tft.print("Temperatura:");
void corriente(){
 float c_TOTAL = 0;
 int contador = 0;
 int Prom = 10;
 while ( contador < Prom ){
 int c_READ = analogRead (A2);
 float c_VOLT= c_READ*(5/1023);
 c_TOTAL += c_VOLT;
 contador +=1;
 float c_CORR = c_TOTAL / Prom;
 String corrString = String(c_CORR)+"mA";
 tft.setCursor(10,120);
 tft.setTextSize(1);
 tft.print(corrString);
 delay(50);
 void temperatura(){
   myUART.println("T?");
   while (myUART.available() > 0) {
   char temp = myUART.read();
   delay(50);
   String tempString = String(temp)+"°C";
   tft.setCursor(10,100); // Corrido de donde esta la corriente puesta
   tft.setTextSize(1);
   tft.print(tempString);
 corriente();
 temperatura();
The errros are the following:
C:\Users\Reymi\Documents\Arduino\PE\PE.ino: In function 'void temperatura()':
PE:136:23: error: lvalue required as decrement operand
136 | myUART.println("T?");
exit status 1
EDIT: Only those two errors are giving me problems now. Thanks to both comments below.
doesn't the UNO have only 6 analog inputs: A0 - A5
gcjr:
Indeed that was the problem.
Now I only need help with the last two errors.
Start with removing this decorative line of minuses. It's being interpreted by the complier.
  tft.setRotation(0);
yfuq:
 tft.setRotation(0);
Thank you very much sir.
All errors have been solved
