I want to send data from multiple esp32 (one at a time) to one esp32. I saw the ble examples but i want an esp32 ble server and multiple clients that send data to server (one at a time). In example the server send data to the client. What should i do?
The ESP32 has another possability to exchange data wireless,
which is called ESP-NOW. With ESP-NOW all ESP32-microcontrollers can exchange data between each other including broadcasting. So you yourself would have to code all the details about server and clients.
here is a demo-code
// WARNING !! Trying to adapt this ESP32-code using ESP-NOW to a ESP8266 is a big hassle
// as the ESP8266-ESP-NOW-library works very differently using other functions etc.
// for coding with an ESP8266 start with a code that is written for ESP8266 DON'T try to adapt an ESP32-code
//WiFiLib and Esp-NowLib espnowlib
#include <WiFi.h> // ESP32 needs "WiFi.h" ESP8266 needs "ESP8266WiFi.h"
#include <esp_now.h> // ESP32 needs "esp_now.h" ESP8266 needs "espnow.h" do you recognize the difference?
#define CHANNEL 0
boolean gb_SerialOutput_enabled = true;
using MacAdr = uint8_t[6];
// the code must know all receivers MAC-adresses that THIS boards wants to send data to
MacAdr ESP_NOW_MAC_adrOfRecv1 { 0x24, 0x0A, 0xC4, 0x06, 0xC3, 0x64 };
MacAdr ESP_NOW_MAC_adrOfRecv2 { 0x24, 0x0A, 0xC4, 0x02, 0xBC, 0x20 };
MacAdr ESP_NOW_MAC_adrOfRecv3 { 0x24, 0x6F, 0x28, 0x22, 0x62, 0xFC };
MacAdr SendersOwnMacAdress { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
void SetupOwnMacAdress(){
memcpy (SendersOwnMacAdress, ESP_NOW_MAC_adrOfRecv3, sizeof(SendersOwnMacAdress) );
boolean New_ESP_DataReceived = false;
esp_now_peer_info_t peerInfo;
void RegisterPeer(const MacAdr &MyMac_Adress_array) {
memcpy(peerInfo.peer_addr, MyMac_Adress_array, sizeof(peerInfo.peer_addr) );
peerInfo.channel = 0;
peerInfo.encrypt = false;
if (esp_now_add_peer(&peerInfo) != ESP_OK)
{ if (gb_SerialOutput_enabled)
{ Serial.println("Failed to add peer"); }
return;
//nbt nonblockingtimer
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
if ( currentMillis - expireTime >= TimePeriod )
expireTime = currentMillis; // set new expireTime
return true; // more time than TimePeriod) has elapsed since last time if-condition was true
else return false; // not expired
unsigned long BlinkTimer = 0;
const int OnBoardLED = 2;
unsigned long SendDataTimer = 0;
// pslib pstringlib
#include <PString.h> // the use of PString avoids code-malfunction like Strings can do
char TestESP_CmdStr_AoC[64];
PString TestESP_CmdStr_PS(TestESP_CmdStr_AoC, sizeof(TestESP_CmdStr_AoC) );
// pfndt
void PrintFileNameDateTime() {
Serial.print("Code running comes from file "); Serial.println(__FILE__);
Serial.print("compiled "); Serial.print(__DATE__); Serial.print(" "); Serial.println(__TIME__);
// pma pwma
void PrintWiFiMacAdress() {
char MacAdr_AoC[18]; //suffix _AoC for easier remembering variable-type is ArrayOfChar
char HexByteDigits[3];
for (uint8_t i = 0; i < 18; i = i + 1){
MacAdr_AoC[i] = WiFi.macAddress()[i];
MacAdr_AoC[17] = 0; // zero to terminate the string
Serial.print("ESP Board Wifi.macAddress: ");
Serial.println(MacAdr_AoC);
Serial.println("copy the line below and replace the '#' with variablename of your choice");
Serial.print("uint8_t #[] = { ");
for (uint8_t i = 0; i < 16; i = i + 3)
HexByteDigits[0] = MacAdr_AoC[i];
HexByteDigits[1] = MacAdr_AoC[i + 1];
HexByteDigits[2] = 0; // zero for terminating the string
Serial.print("0x");
Serial.print(HexByteDigits);
if (i < 14) Serial.print(", ");
Serial.println(" };");
// espnowmsg espnowbytes enbytes espstruc
// Structure example to send data. Must match the receiver structure
typedef struct MyESP_NOW_Data_type {
char MyESP_NOW_SenderID_AoC[16];
char MyESP_NOW_StatusMsg_AoC[64];
int MyESP_NOW_Int;
float MyESP_NOW_Float;
} MyESP_Data_type;
MyESP_NOW_Data_type ESP_Data_Received;
MyESP_NOW_Data_type ESP_Data_ToSend;
// Init ESP Now with restart in case something went wrong
void InitESPNow() {
{ if (esp_now_init() == ESP_OK)
{ Serial.println("ESPNow Init Success"); }
{ Serial.println("ESPNow Init Failed");
ESP.restart(); //there was an error try again through restarting the board
void ESP_NOW_Setup() {
WiFi.mode(WIFI_STA); //Set device in STA mode to begin with
WiFi.disconnect(); // for strange reasons WiFi.disconnect(); is nescessary to make ESP-NOW work
{ Serial.println("WiFi.mode(WIFI_STA WiFi.disconnect() done");}
InitESPNow(); // Init ESPNow with a fallback logic
esp_now_register_send_cb(OnDataSent);
esp_now_register_recv_cb(OnDataRecv);
RegisterPeer(ESP_NOW_MAC_adrOfRecv1);
RegisterPeer(ESP_NOW_MAC_adrOfRecv2);
RegisterPeer(ESP_NOW_MAC_adrOfRecv3);
void PrintESP_Status(esp_err_t result) {
Serial.print("Send Status: ");
if (result == ESP_OK)
{ Serial.println("sended"); }
else if (result == ESP_ERR_ESPNOW_NOT_INIT)
{ Serial.println("Master ESPNOW not Init."); }
else if (result == ESP_ERR_ESPNOW_ARG)
{ Serial.println("Master Invalid Argument"); }
else if (result == ESP_ERR_ESPNOW_INTERNAL)
{ Serial.println("Master Internal Error");}
else if (result == ESP_ERR_ESPNOW_NO_MEM)
{ Serial.println("Master ESP_ERR_ESPNOW_NO_MEM"); }
else if (result == ESP_ERR_ESPNOW_NOT_FOUND)
{ Serial.println("Master Peer not found."); }
{Serial.println("Master Not sure what happened"); }
void SendData() {
{ Serial.println("sendData() Start");}
esp_err_t result;
if(memcmp(ESP_NOW_MAC_adrOfRecv1, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) != 0) { // if MAC-Adess is not the own MAC-Adress
result = esp_now_send(ESP_NOW_MAC_adrOfRecv1, (uint8_t *) &ESP_Data_ToSend, sizeof(ESP_Data_ToSend));
// if sending has finished function OnDataSent is called
if(memcmp(ESP_NOW_MAC_adrOfRecv2, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) != 0) {
result = esp_now_send(ESP_NOW_MAC_adrOfRecv2, (uint8_t *) &ESP_Data_ToSend, sizeof(ESP_Data_ToSend));
if(memcmp(ESP_NOW_MAC_adrOfRecv3, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) != 0) {
result = esp_now_send(ESP_NOW_MAC_adrOfRecv3, (uint8_t *) &ESP_Data_ToSend, sizeof(ESP_Data_ToSend));
// callback-function that is executed when data was send to another ESP32-board
// parameter status contains info about the success or fail of the transmission
void OnDataSent(const uint8_t *Receivers_mac_addr, esp_now_send_status_t status) {
char Receivers_macStr[18];
snprintf(Receivers_macStr, sizeof(Receivers_macStr), "%02x:%02x:%02x:%02x:%02x:%02x",Receivers_mac_addr[0], Receivers_mac_addr[1], Receivers_mac_addr[2], Receivers_mac_addr[3], Receivers_mac_addr[4], Receivers_mac_addr[5]);
Serial.print("callback-OnDataSent ");
Serial.print("ESP32-Board Last Packet Sent to: ");
Serial.println(Receivers_macStr);
Serial.print("ESP32-Board1 Last Packet Send Status: ");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Failed");
// callback-function that is executed when a ESP-NOW-Message is received
void OnDataRecv(const uint8_t *Senders_mac_addr, const uint8_t *receivedBytes, int NoOfreceivedBytes) {
memcpy(&ESP_Data_Received, receivedBytes, sizeof(ESP_Data_Received)); // just copy data to structured variable
New_ESP_DataReceived = true; // and set Flag true
void DisplayESP_Data() {
Serial.println("callback-OnDataRecv ");
char Senders_macStr[18]; //MAC-Adress of sender
snprintf(Senders_macStr, sizeof(Senders_macStr), "%02x:%02x:%02x:%02x:%02x:%02x", Senders_mac_addr[0], Senders_mac_addr[1], Senders_mac_addr[2], Senders_mac_addr[3], Senders_mac_addr[4], Senders_mac_addr[5]);
Serial.print("received from MAC-Adress");
Serial.println(Senders_macStr);
Serial.println("receievd data:");
Serial.print("SenderID #");
Serial.print(ESP_Data_Received.MyESP_NOW_SenderID_AoC);
Serial.println("#");
Serial.print("StatusMsg #");
Serial.print(ESP_Data_Received.MyESP_NOW_StatusMsg_AoC);
Serial.print("Integer:");
Serial.print(ESP_Data_Received.MyESP_NOW_Int);
Serial.print("Float:");
Serial.print(ESP_Data_Received.MyESP_NOW_Float);
void SetupMessageToSend() {
//1
if(memcmp(ESP_NOW_MAC_adrOfRecv1, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) == 0) { // if MAC-Adess1 IS the own MAC-Adress
memcpy(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC, "ESP32-Board1111", sizeof(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC) );
memcpy(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC, " I am Board No 1", sizeof(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC) );
ESP_Data_ToSend.MyESP_NOW_Int = ESP_Data_ToSend.MyESP_NOW_Int + 1;
ESP_Data_ToSend.MyESP_NOW_Float = 111.111;
//2
if(memcmp(ESP_NOW_MAC_adrOfRecv2, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) == 0) { // if MAC-Adess2 IS the own MAC-Adress
memcpy(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC, "ESP32-Board2222", sizeof(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC) );
memcpy(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC, " I am Board No 2", sizeof(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC) );
ESP_Data_ToSend.MyESP_NOW_Int = ESP_Data_ToSend.MyESP_NOW_Int + 2;
ESP_Data_ToSend.MyESP_NOW_Float = 222.222;
//3
if(memcmp(ESP_NOW_MAC_adrOfRecv3, SendersOwnMacAdress, sizeof(SendersOwnMacAdress) ) == 0) { // if MAC-Adess3 IS the own MAC-Adress
memcpy(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC, "ESP32-Board3333", sizeof(ESP_Data_ToSend.MyESP_NOW_SenderID_AoC) );
memcpy(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC, " I am Board No 3", sizeof(ESP_Data_ToSend.MyESP_NOW_StatusMsg_AoC) );
ESP_Data_ToSend.MyESP_NOW_Int = ESP_Data_ToSend.MyESP_NOW_Int + 3;
ESP_Data_ToSend.MyESP_NOW_Float = 333.333;
{ PrintFileNameDateTime(); }
ESP_NOW_Setup();
{ PrintWiFiMacAdress(); }
pinMode(OnBoardLED,OUTPUT);
if ( TimePeriodIsOver(BlinkTimer,500) ) {
digitalWrite (OnBoardLED, !digitalRead(OnBoardLED) );
if ( TimePeriodIsOver(SendDataTimer,2000) ) {
SetupMessageToSend();
SendData();
best regards Stefan
