Multiple ESP32 OTA updating
I'm looking for a way to update multiple ESP32 via OTA, I want to be able to update them without being in the same WiFi connection, also, how to also implement it through a GSM connection would be much appreciated. Im using platformio in VS code.
If you can provide the ESP32 with a source of the new binary, you can use httpUpdater
Any good info about how to implement it?
menitox:
I think it's the OTAWebUpdater example that you want. It's quite a bit different in how it is setup from the ESP8266 example, but it doesn't look that much more complicated. As a huge advantage over that it has, that the UI is outside of the library.
