Multiple Files in Library folder
Hi everyone!
I have multiple files in my custom library folder, and I get this error when I try to compile:
TFT_Objects\TFT_Box.cpp.o: In function `TFT_Box::TFT_Box(UTFT*, UTouch*, UTFT_Geometry*)':
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::TFT_Box(UTFT*, UTouch*, UTFT_Geometry*)'
TFT_Objects\TFT_Box.cpp.o:C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: first defined here
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.8.1/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::sort()'
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::sortReverse()'
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::reverse()'
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::shuffle()'
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::lower()'
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::upper()'
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::size()'
C:\Users\Giovanni\Documents\Arduino\libraries\TFT_Objects/TFT_Box.cpp:7: multiple definition of `TFT_Box::getItem(int, char*, int)'
/* + 300 lines of code of same nature */
Edit: ZIP with files attached.
My library folder looks like this (it is in the ...\Documents\Arduino):
TFT_Objects/
   keywords.txt
   TFT_Box.h
   TFT_Box.cpp
   TFT_Grid.h
   TFT_Grid.cpp
   utility/
      strFunctions.h
      strFunctions.cpp
      colorTheme.h
      colorTheme.cpp
TFT_ObjectsTest.ino file:
#include <UTFT.h>
#include <UTouch.h>
#include <UTFT_Geometry.h>
#include <TFT_Box.h>
#include <TFT_Grid.h>
UTouch        myTouch( 6, 5, 4, 3, 2);
UTFT          myGLCD(TFT01_32,38,39,40,41);
UTFT_Geometry myGeo(&myGLCD);
TFT_Box       myComboBox(&myGLCD, &myTouch, &myGeo);
TFT_Grid      myListBox(&myGLCD, &myTouch);
/* code */
TFT_Box.h :
# ifndef TFT_Box_h
# define TFT_Box_h
#include <Arduino.h>
#include <UTFT.h>
#include <UTouch.h>
#include <string.h>
#include "utility/colorTheme.h"
#include "utility/strFunctions.h"
class TFT_Box {
  /* code */
#endif
TFT_Grid.h :
# ifndef TFT_Grid_h
# define TFT_Grid_h
#include <UTFT.h>
#include <UTouch.h>
#include <string.h>
class TFT_Grid {
  /* code */
#endif
strFunctions.h:
#ifndef strFunctions_h
#define strFunctions_h
/* code */
#endif
colorTheme.h:
#ifndef colorTheme_h
#define colorTheme_h
/* code */
#endif
All my .cpp files have just this at the beginning:
#include "[correspondent header file].h"
/* code */
PS: I omitted the code that weren't related to "file included", because I think it's not relevant to the problem, all functions have different names.
I can't get it to compile.
Any help would be appreciated. :slight_smile:
TFT_Objects.zip (627 KB)
So would a zip file of all of your code, if you really expect help.
I'm sorry (again).
I've attached the zip with the files!
Your sketch references
which is not in the zip file.
Updated the zip and included the remaining necessary libraries.
Well, I unzipped your file, put the libraries in the libraries folder, put the sketch in the appropriate sketch folder, and compiled. I only got one error:
Binary sketch size: 44,476 bytes (of a 258,048 byte maximum)
After seeing your answer, instantly I thought about the IDE version.
I was using 1.6.6 (Hourly build / beta), after testing with 1.6.5 it just worked.
Thanks for the help! Next time I will try with other IDE too...
Why? Are you a beta tester?
giova014:
I usually test with 1.0.6.
Why get the latest, greatest, bugs? It's not as if the more recent IDEs have a better video card driver on them.
PaulS:
It's a habit of having "the latest", but obviously unnecessary, because it would solve no problems that I had and even create others (this case).
Something I will think thrice before upgrading...
