Greetings to everyone!
How can I execute 2 dual for loops at the same time? Basically I want Servo 1 and Servo 2 to function at the same time. My current problem is The Servo 1 will execute 1st and then Servo 2 will follow. I hope anyone can get my problem. Here's the code:
Thank you in Advance.
#include <Servo.h>
Servo myservo1; // 20 degrees initial value
Servo myservo2; // 180 degrees initial value
// twelve servo objects can be created on most boards
int pos, pos1;Â Â // variable to store the servo position
 myservo1.attach(9);
 myservo2.attach(8);
 // Servo 1
 for (pos = 20; pos <= 90; pos++) { // goes from 0 degrees to 180 degrees
  // in steps of 1 degree
  myservo1.write(pos);       // tell servo to go to position in variable 'pos'
  delay(15);           // waits 15ms for the servo to reach the position
 for (pos = 90; pos >= 20; pos--) { // goes from 180 degrees to 0 degrees
Â
 //Servo 2
 for (pos1 = 180; pos >= 110; pos--) { // goes from 0 degrees to 180 degrees
  myservo2.write(pos);       // tell servo to go to position in variable 'pos'
 for (pos1 = 110; pos <= 180; pos++) { // goes from 180 degrees to 0 degrees
