Greetings to all of you.
I am currently working on a project assignment, a radio that can do voice and data communication in VHF. I am already done with the voice but still have no any idea about the data. So, the data that I want to send among the radios is GPS data. I've tried with the rf 433 but then realised that it only uses one fixed frequency.
For my project, I want it to be multiple channel of bandwidth in one radio for the data communication, like handy talkie but the frequencies will be limited and allocated into different channels. Is it possible to do it with arduino? If it's possible, can you give me any ideas on what modules or hardware to use for my project? My knowledge about arduino and RF is not that broad yet so please help me out.
Any help would be appreciated. Thank you very much!
For music you need frequency from 40Hz to 20kHz, that is your first "green" channel
So data frequency must be above that, 25kHz - the second channel , next 30 kHz .....
on receiving side you need Band-pass Filters for 25kHz, 30kHz ...
The limit is only the bandwidth of Tx and Rx
Similar way is working TV cable
start with 1 channel.
Make a generator let say 25kHz, connect it to Tx, make LC filter for that frequency and connect it to output of Rx , look on oscilloscope presents of 25 kHz on the filter.
marikamarika:
What was your solution for voice communications? Do I understand correctly you want to use the same physical transmitter to send data? At least one problem is that 433 MHz is not a voice band so there are legality issues in doing what you seem to propose.
It might be helpful if you described what you want to do with the various channels. In particular if you're just sending multiple data types or sending unique data to one of multiple receivers, there may be better ways to do this.
If you truly need multiple RF channels at 433 MHz, the HC-12 transceivers are tuneable.
marikamarika:
To answer that specific question; if as you say the project requires multiple channels (in one radio) then there are a number of possibilities that are not expensive, but you do need to provide more details.
The worst choice, for such a multiple channel system, would be the el-cheapo 433Mhz modules you see often on eBay. These devices are usually fixed frequency so of no use in a multiple channel system.
If this is a project assignment then you should of course be presenting a 'solution' that is legal to use.
