Multiple Hits with Debounced Switch on Interrupt
Hello, I have a hardware debounced switch with a Schmitt trigger. I run the following code:
int buttonInt0 = 0; //digital pin2
int mode;
//attach interrupt
attachInterrupt(buttonInt0, button_down, FALLING);
void button_down()
mode = 1;
if (mode == 1)
Serial.println("UP");
mode = 0;
When I open the serial monitor and depress the switch "UP" is printed 6 or so times. I would expect it should only be printed once. Why is this? I checked my switch output on the scope and it looks clean.
A couple of questions. The values that you assign to mode are 0 and 1. Those values both fit in a byte.
You are referencing mode in both loop() and the ISR, and yet mode is not declared volatile. Why not?
In short, I don't know any better. :slight_smile:
What you have to understand is that the resolution of digital electronics is a few nanoseconds, and things like contact-bounce in switches are on a timescale of milliseconds. Thus every bounce of the metal contacts in the switch will cause a new switching transition on the pin that's generating interrupts.
The solution to this contact bounce is not a schmidt-trigger (thats only needed for slowly varying waveforms), but is either
  1. software debouncing - ignore all transitions that occur within a certain time of the first transition. Timescale of 10ms would normally surfice.
  2. pass the output from the switch through a low-pass-filter to smear-out the bounces, then pass that signal through a schmidt-trigger to turn it back to a digital signal.
Perhaps I will be more specific. Here is the circuit I am using: How to debounce a switch
It is a combination schmitt trigger with a rc circuit.
