multiple if but one cases always on
so i was working on project where there is 4 switch and its working as biner number
example :
s1 0, s2 0, s3 0, s4 1 = LED1 will be on
s1 1, s2 0, s3 1, s4 1 = LED 11 will be on
i write code like this but why LED 15 always on which mean all my switch is pressed
  pinMode(0,INPUT);
  pinMode(1,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(13,OUTPUT);
  pinMode(14,OUTPUT);
  pinMode(15,OUTPUT);
  pinMode(16,OUTPUT);
  pinMode(17,OUTPUT);
  pinMode(18,OUTPUT);
  pinMode(19,OUTPUT);
void loop()  {
if ( (digitalRead(0) == LOW) && (digitalRead(1) == LOW) && (digitalRead(2) == LOW) && (digitalRead(3) == LOW)){
    Serial.println("0");
    digitalWrite(4,LOW);
    digitalWrite(5,LOW);
    digitalWrite(6,LOW);
    digitalWrite(7,LOW);
    digitalWrite(8,LOW);
    digitalWrite(9,LOW);
    digitalWrite(10,LOW);
    digitalWrite(11,LOW);
    digitalWrite(12,LOW);
    digitalWrite(13,LOW);
    digitalWrite(14,LOW);
    digitalWrite(15,LOW);
    digitalWrite(16,LOW);
    digitalWrite(17,LOW);
    digitalWrite(18,LOW);
else if ( (digitalRead(0) == LOW) &&
       (digitalRead(3) == HIGH)){
  Serial.println("1");
    digitalWrite(4,HIGH);
       (digitalRead(2) == HIGH) &&
        Serial.println("2");
    digitalWrite(5,HIGH);
        Serial.println("3");
    digitalWrite(6,HIGH);
        Serial.println("4");
    digitalWrite(7,HIGH);
        Serial.println("5");
    digitalWrite(8,HIGH);
       (digitalRead(1) == HIGH) &&
        Serial.println("6");
    digitalWrite(9,HIGH);
        Serial.println("7");
    digitalWrite(10,HIGH);
sub.ino (9.59 KB)
If you post your code as described in the how to use his forum sticky more members will see it and you may get more and faster help.
else if ( (digitalRead(0) == HIGH) &&
Serial.println("8");
digitalWrite(11,HIGH);
Serial.println("9");
digitalWrite(12,HIGH);
Serial.println("10");
digitalWrite(13,HIGH);
Serial.println("11");
digitalWrite(14,HIGH);
Serial.println("12");
digitalWrite(15,HIGH);
Serial.println("13");
digitalWrite(16,HIGH);
Serial.println("14");
digitalWrite(17,HIGH);
else{
Serial.println("15");
digitalWrite(18,HIGH);
Please read the 'how to post' sticky again.
Which Arduino are you using.
Pin0 and pin1 can't be used on most Arduinos, because they are already used by the USB<>Serial chip.
And pin 14, 15, etc are different pins on different Arduinos.
Most blocks in your code can be replaced by one line.
Example:
for(int i = 4; i <= 18; i++) digitalWrite(i, HIGH); // set pin4-18 HIGH
Leo..
Perhaps if the conditions for 12 and 13 weren't the same as for 10 and 11 it would help.
Steve
