Multiple if commands for turning the robot
I am working on a robot that evades objects. At the start I wanted to give it a servo to check left and right to see wich direction its safe to turn to. Sadly servo broke and I dont have time to order a new one. Basically, I wanted to make the robot (has the sensor at the front) to turn right (because after the turn its still basicly on the same postion, just turned) to give it the same effect as servo checking right and left.
And if the sensor sees the path is clear, the robot should move forward. If not, it should check right side as well and go forward if its clear. If not, turn back in the initial position and go backwards, then repeat the checking again and go where its safe.
The time for the robot to turn for 90 degrees is about 0,7 seconds (700).
At the moment the code is made so that the robot always goes to the right when sees a object. I don't know how to make multiple "if" one after another.
Thanks for any help, the code is below:
//Libraries
#include "Ultrasonic.h"
//Constants
const int button = 2;
const int led    = 3;
const int buzzer = 4;
const int motorA1= 6;     //motor A pos
const int motorA2= 9;     //motor A neg
const int motorB1=11;     //motor B pos
const int motorB2=10;     //motor B neg
Ultrasonic ultrasonic(A4 ,A5);
//Variables
int distance;         //sensor
int function=0;       //1 robot moving , 0 not moving
int buttonState=0;    //button
int flag=0;           //button hold
  pinMode(button, INPUT_PULLUP);
  pinMode(led,  OUTPUT);
  pinMode(motorA1,OUTPUT);
  pinMode(motorA2,OUTPUT);
  pinMode(motorB1,OUTPUT);
  pinMode(motorB2,OUTPUT);
  buttonState = digitalRead(button);
    if (buttonState == LOW) {//If button is pressed once...
      if ( flag == 0){
          function = 1;
          flag=1; //change flag variable
      else if ( flag == 1){  //If button is pressed twice
        function = 0;
        flag=0; //change flag variable again
      if (function == 0){   //button pressed twice
    stop();         //robot se ustavi
    digitalWrite(led, HIGH); // led on
else if (function == 1){ //If button is pressed then:
    //Read distance...
    distance = ultrasonic.Ranging(CM); //Tip: Use 'CM' for centimeters or 'INC' for inches
    //Check for objects...
    if (distance > 15){
      forward(); //All clear, move forward!
      digitalWrite(led,LOW);
    else if (distance <=15){
      stop(); //Object detected! Stop the robot and check left and right for the better way out!
      digitalWrite(led,HIGH); // turn the led on
      delay(600);
      right();
      delay(900);
      forward;
void forward(){
  digitalWrite(motorA1, HIGH);
  digitalWrite(motorA2, LOW);
  digitalWrite(motorB1, HIGH);
  digitalWrite(motorB2, LOW);
void backward(){
  digitalWrite(motorA1, LOW);
  digitalWrite(motorA2, HIGH);
  digitalWrite(motorB1, LOW);
  digitalWrite(motorB2, HIGH);
void left(){
void right(){
void stop(){
Why do you have flag and function always having the same value?
    if (distance > 15){
If the value in distance is not greater than 15, what are the odds that it is not less than or equal to 15? When a condition absolutely, positively MUST be true, there is no point checking, is there?
      right();
      delay(900);
      forward;
What is that last line of code doing?
help me ):
I think your code needs to behave like this pseudo code - not tested.
(assume it is called repeatedly from loop() and there are no delay()s in your code)
check For Obstacle
   if no obstacle
      move forward
      checkRight = false
      checkLeft = false
      if checkRight == false
          turn Right
          checkRight = true
          turn Left
          checkLeft = true
...R
