Hello all,
I am currently building a foot bath to wash cows feet on a farm. There are four baths that the cows walk through after being milked. I have built a panel with a four position selector switch so that farmer can select which bath he would like to fill. A momentary button to say he would like to fill the bath, a maintained button to turn chemical on or off (the first two baths will get soap added and the second two baths will get a chemical added if he chooses) he also has a button to add water for a hard coded amount of time. if his water usage was high at the point of filling he would not get a full bath like he would if no water was being used on the farm. I have also coded a prime pump button to prime 1 of 3 pumps (1 soap 2 chemical) depending on the position of the selector switch. My problem with the following code is that as soon as I move the selector switch to a position it starts filling that bath. The chemical on/off button seems to be working but I am unable to test the add or prime because it instantly starts filling.
any help or suggestions is appreciated!
Code:
// Declare pin names and corresponding arduino pin
const int Bath1Select = A2;
const int Bath2Select = A3;
const int Bath3Select = A4;
const int Bath4Select = A5;
const int ChemOnOff = 0;
const int AddWater = 1;
const int FillWater = 2;
const int PrimePump = 3;
const int Chem1 = 6;
const int Chem2 = 7;
const int Chem3 = 8;
const int MainValve = 9;
const int Bath1Valve = 10;
const int Bath2Valve = 11;
const int Bath3Valve = 12;
const int Bath4Valve = 5;
//Declare Variables with initial values (Ajustable as desired)
int SoapTime = 6000;
int ChemTime = 6000;
int FillTime = 10000;
int AddTime = 6000;
bool FillWaterBit = 0;
bool AddWaterBit = 0;
//This code declares the initial setup when powered up
// Initialize pins as inputs or outputs
pinMode(Bath1Select, INPUT);
pinMode(Bath2Select, INPUT);
pinMode(Bath3Select, INPUT);
pinMode(Bath4Select, INPUT);
pinMode(ChemOnOff, INPUT);
pinMode(AddWater, INPUT);
pinMode(FillWater, INPUT);
pinMode(PrimePump, INPUT);
pinMode(Chem1, OUTPUT);
pinMode(Chem2, OUTPUT);
pinMode(Chem3, OUTPUT);
pinMode(MainValve, OUTPUT);
pinMode(Bath1Valve, OUTPUT);
pinMode(Bath2Valve, OUTPUT);
pinMode(Bath3Valve, OUTPUT);
pinMode(Bath4Valve, OUTPUT);
if (digitalRead(FillWater) == HIGH) { //Bit is lactched when add or fill button is pressed
FillWaterBit = HIGH;
if (digitalRead(AddWater) == HIGH) {
AddWaterBit = HIGH;
if (digitalRead(PrimePump) == HIGH && digitalRead(Bath1Select) == HIGH) { //Pump Priming - While prime button is pressed, the pump 1 , 2 or 3 will pump based on the position of the bath selector switch
digitalWrite(Chem1, HIGH);
if (digitalRead(PrimePump) == HIGH && digitalRead(Bath2Select) == HIGH) {
digitalWrite(Chem2, HIGH);
if (digitalRead(PrimePump) == HIGH && digitalRead(Bath3Select) == HIGH) {
digitalWrite(Chem3, HIGH);
//Bath Filling
if (digitalRead(FillWaterBit) == HIGH && digitalRead(ChemOnOff) == HIGH && digitalRead(Bath1Select) == HIGH) { //FILL BATH 1 CHEM ON
digitalWrite(MainValve, HIGH);
digitalWrite(Bath1Valve, HIGH);
delay(SoapTime);
digitalWrite(Chem1, LOW);
delay(FillTime-SoapTime);
digitalWrite(MainValve, LOW);
digitalWrite(Bath1Valve, LOW);
FillWaterBit = LOW;
if (digitalRead(FillWaterBit) == HIGH && digitalRead(ChemOnOff) == HIGH && digitalRead(Bath2Select) == HIGH) { //FILL BATH 2 CHEM ON
digitalWrite(Bath2Valve, HIGH);
delay(SoapTime);
digitalWrite(Bath2Valve, LOW);
FillWaterBit = LOW;
if (digitalRead(FillWaterBit) == HIGH && digitalRead(ChemOnOff) == HIGH && digitalRead(Bath3Select) == HIGH) { //FILL BATH 3 CHEM ON
digitalWrite(Bath3Valve, HIGH);
delay(ChemTime);
digitalWrite(Chem2, LOW);
delay(FillTime-ChemTime);
digitalWrite(Bath3Valve, LOW);
FillWaterBit = LOW;
if (digitalRead(FillWaterBit) == HIGH && digitalRead(ChemOnOff) == HIGH && digitalRead(Bath4Select) == HIGH) { //FILL BATH 4 CHEM ON
digitalWrite(Bath4Valve, HIGH);
delay(ChemTime);
digitalWrite(Chem3, LOW);
digitalWrite(Bath4Valve, LOW);
FillWaterBit = LOW;
if (digitalRead(FillWaterBit) == HIGH && digitalRead(ChemOnOff) == LOW && digitalRead(Bath1Select) == HIGH) { //FILL BATH 1 CHEM OFF
delay(FillTime);
FillWaterBit = LOW;
if (digitalRead(FillWaterBit) == HIGH && digitalRead(ChemOnOff) == LOW && digitalRead(Bath2Select) == HIGH) { //FILL BATH 2 CHEM OFF
delay(FillTime);
FillWaterBit = LOW;
if (digitalRead(FillWaterBit) == HIGH && digitalRead(ChemOnOff) == LOW && digitalRead(Bath3Select) == HIGH) { //FILL BATH 3 CHEM OFF
delay(FillTime);
FillWaterBit = LOW;
if (digitalRead(FillWaterBit) == HIGH && digitalRead(ChemOnOff) == LOW && digitalRead(Bath4Select) == HIGH) { //FILL BATH 4 CHEM OFF
delay(FillTime);
FillWaterBit = LOW;
if (digitalRead(AddWaterBit) == HIGH && digitalRead(Bath1Select) == HIGH) { // ADD WATER BATH 1
delay(AddTime);
AddWaterBit = LOW;
if (digitalRead(AddWaterBit) == HIGH && digitalRead(Bath2Select) == HIGH) { // ADD WATER BATH 2
delay(AddTime);
AddWaterBit = LOW;
if (digitalRead(AddWaterBit) == HIGH && digitalRead(Bath3Select) == HIGH) { // ADD WATER BATH 3
delay(AddTime);
AddWaterBit = LOW;
if (digitalRead(AddWaterBit) == HIGH && digitalRead(Bath4Select) == HIGH) { // ADD WATER BATH 4
delay(AddTime);
AddWaterBit = LOW;
if (digitalRead(AddWaterBit) == HIGH && digitalRead(Bath1Select) == LOW && digitalRead(Bath2Select) == LOW && digitalRead(Bath3Select) == LOW && digitalRead(Bath4Select) == LOW) { // If Add button is pressed while adding water it will cancel
AddWaterBit = LOW;
if (digitalRead(FillWaterBit) == HIGH && digitalRead(Bath1Select) == LOW && digitalRead(Bath2Select) == LOW && digitalRead(Bath3Select) == LOW && digitalRead(Bath4Select) == LOW) { // If Fill button is pressed while filling it will cancel
FillWaterBit = LOW;
HooveBath.V5.ino (7.4 KB)
