multiple independant soilsensor/waterpump setup timing issue
hello all!
i am currently trying to accomplish the following for greenhouse application:
-automated control of the watering of strawberry rows, (many sensor and relay(waterpumps)
-at the same time collect the sensor reading over an internet shield
-adding various fail safe down the road, so i want to keep this project easy for future addons
what i want from you guys:
helping me resolve a timing issue,
at the moment, i have 2 soil sensor running their own relay (water pump) independant, but im having trouble with the timers.
what happends, if the reading is over 800, sensor1 kicks in after 2-5 sec, then closes after 8 sec
if the reading is over 800, sensor2 kicks in after 8sec, then closes after 20sec
there is a mixed up timer setup in there, what i would like is after the sensor reads over 800, that the relay comes ON instant or 2 sec after is fine, but constant.
i dont want to use delays, and i think the script i have avoids the 50days issue with the millisecond internal clock. if you think it does not let me know!
const int RELAY1= 6;
const int RELAY2= 7;
int RELAYSTATE1 = LOW;
int RELAYSTATE2 = LOW;
int sensorReading1= analogRead(A0);
 int sensorReading2= analogRead(A1);
unsigned long timer[10];
byte timerState[10];
Serial.println("Initializing");
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
digitalWrite(RELAY1,HIGH);
digitalWrite(RELAY2,HIGH);
//the number "1" is the timer used
//The next number "1000" is the delay in milliseconds
  if (delayMilliSeconds(1,2000)){
 Serial.print("Sensor1: ");
 Serial.println (sensorReading1); //prints out the sensor reading
 Serial.print("Sensor2: ");
 Serial.println (sensorReading2); //prints out the sensor reading
  int sensorReading1= analogRead(A0); //reads the sensor value
 if (delayMilliSeconds(2,8000))
   if (sensorReading1> 800){//if reading is above 800
digitalWrite(RELAY1,LOW); //turns the pump on
Serial.print("watering! ");
 else { digitalWrite(RELAY1,HIGH); //turns the pump off after 8sec
 if (delayMilliSeconds(3,20000))
   if (sensorReading2> 800){//if reading is above 800
digitalWrite(RELAY2,LOW); //turns the pump on
 else{digitalWrite(RELAY2,HIGH); //turns the pump off
 //Serial.print("finished watering! ");
// Do something else here if enough time has not passed
//Everything from here down comes after the main "loop()"
int delayHours(byte timerNumber,unsigned long delaytimeH){    //Here we make it easy to set a delay in Hours
  delayMilliSeconds(timerNumber,delaytimeH*1000*60*60);
int delayMinutes(byte timerNumber,unsigned long delaytimeM){    //Here we make it easy to set a delay in Minutes
  delayMilliSeconds(timerNumber,delaytimeM*1000*60);
int delaySeconds(byte timerNumber,unsigned long delaytimeS){    //Here we make it easy to set a delay in Seconds
  delayMilliSeconds(timerNumber,delaytimeS*1000);
int delayMilliSeconds(int timerNumber,unsigned long delaytime){
  unsigned long timeTaken;
  if (timerState[timerNumber]==0){    //If the timer has been reset (which means timer (state ==0) then save millis() to the same number timer,
    timer[timerNumber]=millis();
    timerState[timerNumber]=1;      //now we want mark this timer "not reset" so that next time through it doesn't get changed.
  if (millis()> timer[timerNumber]){
    timeTaken=millis()+1-timer[timerNumber];    //here we see how much time has passed
  else{
    timeTaken=millis()+2+(4294967295-timer[timerNumber]);    //if the timer rolled over (more than 48 days passed)then this line accounts for that
  if (timeTaken>=delaytime) {          //here we make it easy to wrap the code we want to time in an "IF" statement, if not then it isn't and so doesn't get run.
     timerState[timerNumber]=0;  //once enough time has passed the timer is marked reset.
     return 1;                          //if enough time has passed the "IF" statement is true
  else {                               //if enough time has not passed then the "if" statement will not be true.
    return 0;
  if (millis() > timer[timerNumber]) {
    timeTaken = millis() + 1 - timer[timerNumber]; //here we see how much time has passed
  else {
    timeTaken = millis() + 2 + (4294967295 - timer[timerNumber]); //if the timer rolled over (more than 48 days passed)then this line accounts for that
You have made things unnecessarily complicated. If you simply subtract the millis() value of when a state started from the current millis() value and compare it with the required period then the 49 day millis() rollover is automatically taken care of.
thanks for the input!
Ive been able to put this together, still one thing that does not work, the RelayPin1 comes ON when its over 800 after 1sec, that part works, but not until the value goes under 800 that the else if comes into play to shut down the relay 8 sec later
    const int RelayPin1 =  6;
    int RelayState1 = LOW;
    unsigned long previousMillis1 = 0;
    long OnTime1 = 2000;
    long OffTime1 = 750;
    const int RelayPin2 =  7;
    int RelayState2 = LOW;
    unsigned long previousMillis2 = 0;
    long OnTime2 = 1000;
    long OffTime2 = 8000;
unsigned long previousMillis3 = 0;
 const int sensorReading1= analogRead(A0);
const int sensorReading2= analogRead(A1);
      pinMode(RelayPin1, OUTPUT);
      pinMode(RelayPin2, OUTPUT);
      digitalWrite(RelayPin1,HIGH); //turns the pump off
      digitalWrite(RelayPin2,HIGH);
  if (currentMillis - previousMillis1 >= OnTime1)
   previousMillis1 = currentMillis;
 if ((sensorReading1>= 800) && (currentMillis - previousMillis2 >= OnTime2))
        digitalWrite(RelayPin1,LOW); //turns the pump on
        previousMillis2 = currentMillis;  // Remember the time
        else if((RelayState1==LOW)&&(currentMillis - previousMillis2 >= OffTime2))
ill continue working on it tomorrow, in the mean time if someone knows what’s wrong or can easely correct what im doing wrong, that would be great. Ill keep updating on my progress, thanks in advance!
I have made a few changes in this each marked with //======
You had some unncessary and confusing int definitions. Just define a variable in one place
int sensorReading1 = 0;  // ====== you can't read values here
int sensorReading2 = 0;  // ====== don't make variables CONST
		sensorReading1= analogRead(A0); //reads the sensor value //======== Don't redefine variables
		sensorReading2= analogRead(A1);   //========
	sensorReading1= analogRead(A0); //======== why is this here ?
...R
thanks robin for the heads up! i do alot of copy/paste and those things slipped my mind, and im still new to the arduino programming so sometimes i cant see if its needed or not.
anyway, i think i got it to work except a minor glitch but that not too bad(until the sensor reads over 600, its gonna keep saying watering! every 1sec)
    long OffTime2 = 15000;
long OnTime3 = 1000;
    long OffTime3 = 30000;
int sensorReading2 = 1;
 if ((sensorReading1>= 600) && (currentMillis - previousMillis2 >= OnTime2))
       if ((sensorReading2>= 600) && (currentMillis - previousMillis3 >= OnTime3))
        digitalWrite(RelayPin2,LOW); //turns the pump on
        previousMillis3 = currentMillis;  // Remember the time
        else if((RelayState2==LOW)&&(currentMillis - previousMillis3 >= OffTime3))
if you guys got some input let me know! so far im gonna go with this.
Oh and please, i know the millis() gets reset, but just to ease my mind, can you guys confirm those
loops wont be affected by the 49days end of timer issue, thanks in advance!
The use of subtraction in determining whether the required period has elapsed and the use of unsigned long variables assures that the rollover of millis() to zero will not affect the timing.
alphagreen:
To stop that you need a variable to record the fact that it has started watering. You could also use that as a substitute for checking
every iteration of loop()
As you have noted these are just cosmetic changes and should not affect the functioning of the system
...R
