Multiple, independent delays
A newby question......
I have four outputs that are dependent on a trigger event. The first output would start anywhere between 10 and 100 milliseconds after the trigger, and the next three would happen between 0 and 999 microseconds after the first output, each of the three having the option of a different delay, i.e.;
Trigger
Output 1: 10 - 100 msec after trigger
Output 2: 0 - 999 usec after Output 1
Output 3: 0 - 999 usec after Output 1
I'm in an endless loop trying to figure this out. Any suggestions? Is this even possible?
Is there a tiping error? Shouldnt it say output 1, 2 , 3 and 4?
Anyway, it is possible and it's not complex. Check the example "blink withouth delay" and learn the use of millis().
Microsecond accuracy - tricky.
Post what you've got.
mart256:
sp. " learn the use of micros()."
this is with millis() not micros()
but you get the point:
untested
int led[4] = {2,3,4,5};
int trigger = 0;
int oldTrigger = 1;
unsigned long startTime;
int out[4];
  for (int i = 0; i < 4; i++)
    pinMode(i, OUTPUT);
  if (trigger!=oldTrigger)
    startTime = millis();
    out[0] = random(10,100);
    out[1] = random(0,999);
    out[2] = random(0,999);
    out[3] = random(0,999);
      Serial.println(out[i]);
  oldTrigger = trigger;
    ledON(led[i], out[i]);
void ledON(int myLed, int myDelay)
  if (millis() - startTime > myDelay)
    digitalWrite(myLed, HIGH);
I found this site to be really helpful with projects like this.
http://www.thebox.myzen.co.uk/Tutorial/State_Machine.html
This demo several things at a time is an extended example of the BWoD technique.
Micros() has a minimum resolution of 4 usecs.
...R
mart256:
My little bit of code:
// Blink without "delay()" - multi!
const int led1Pin =  13;    // LED pin number
const int led2Pin =  10;
const int led3Pin =  11;
int led1State = LOW;        // initialise the LED
int led2State = LOW;
int led3State = LOW;
unsigned long count1 = 0;   // will store last time LED was updated
unsigned long count2 = 0;
unsigned long count3 = 0;
// Have we completed the specified interval since last confirmed event?
// "marker" chooses which counter to check
boolean timeout(unsigned long *marker, unsigned long interval) {
  if (millis() - *marker >= interval) {
    *marker += interval;    // move on ready for next interval
    return true;
  else return false;
// Deal with a button read; true if button pressed and debounced is a new event
// Uses reading of button input, debounce store, state store and debounce interval.
boolean butndown(char button, unsigned long *marker, char *butnstate, unsigned long interval) {
  switch (*butnstate) {               // Odd states if was pressed, >= 2 if debounce in progress
  case 0: // Button up so far,
    if (button == HIGH) return false; // Nothing happening!
    else {
      *butnstate = 2;                 // record that is now pressed
      *marker = millis();             // note when was pressed
      return false;                   // and move on
  case 1: // Button down so far,
    if (button == LOW) return false; // Nothing happening!
    else {
      *butnstate = 3;                 // record that is now released
      *marker = millis();             // note when was released
  case 2: // Button was up, now down.
    if (button == HIGH) {
      *butnstate = 0;                 // no, not debounced; revert the state
      return false;                   // False alarm!
    else {
        *butnstate = 1;               // jackpot!  update the state
        return true;                  // because we have the desired event!
        return false;                 // not done yet; just move on
  case 3: // Button was down, now up.
    if (button == LOW) {
      *butnstate = 1;                 // no, not debounced; revert the state
    else {
        *butnstate = 0;               // Debounced; update the state
        return false;                 // but it is not the event we want
  default:                            // Error; recover anyway
      *butnstate = 0;
      return false;                   // Definitely false!
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(led3Pin, OUTPUT);
  // Act if the latter time (ms) has now passed on this particular counter,
  if (timeout(&count1, 500UL )) {
    if (led1State == LOW) {
      led1State = HIGH;
    else {
      led1State = LOW;
    digitalWrite(led1Pin, led1State);
  if (timeout(&count2, 300UL )) {
    if (led2State == LOW) {
      led2State = HIGH;
    else {
      led2State = LOW;
    digitalWrite(led2Pin, led2State);
  if (timeout(&count3, 77UL )) {
    if (led3State == LOW) {
      led3State = HIGH;
    else {
      led3State = LOW;
    digitalWrite(led3Pin, led3State);
Make of it what you will. :smiley:
JimboZA:
mart256:
I don't understand the joke, but seems funny. 8)
mart256:
You indeed had a spelling error in the word "typing".
It is rather funny. I am sure there is a word for that, but it quite escapes me at this time of evening.
Paul__B:
Irony?
Thanks, I'll practice my english.
Thank you all much for your help, yeah I meant to have outputs 1-4. I'll try these suggestions. Cheers!
