Ok, I have it one potentiometer controlling 4 digital outputs:
Analog Input
Demonstrates analog input by reading an analog sensor on analog pin 0 and
turning on and off a light emitting diode(LED) connected to digital pin 13.
The amount of time the LED will be on and off depends on
the value obtained by analogRead().
The circuit:
* Potentiometer attached to analog input 0
* center pin of the potentiometer to the analog pin
* one side pin (either one) to ground
* the other side pin to +5V
* LED anode (long leg) attached to digital output 13
* LED cathode (short leg) attached to ground
* Note: because most Arduinos have a built-in LED attached
to pin 13 on the board, the LED is optional.
Created by David Cuartielles
modified 30 Aug 2011
By Tom Igoe
This example code is in the public domain.
http://arduino.cc/en/Tutorial/AnalogInput
int sensorPin = A0; // select the input pin for the potentiometer
int ledPin = 0; // select the pin for the LED
int sensorValue = 0; // variable to store the value coming from the sensor
int sensorPin1 = A1;
int ledPin1 = 1;
int sensorPin2 = A2;
int ledPin2 = 2;
int sensorPin3 = A3;
int ledPin3 = 3;
// declare the ledPin as an OUTPUT:
pinMode(ledPin, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin3, HIGH);
// stop the program for <sensorValue> milliseconds:
delay(sensorValue);
// turn the ledPin off:
digitalWrite(ledPin, LOW);
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
// stop the program for for <sensorValue> milliseconds:
delay(sensorValue);
Any thoughts on how to have each output read from a different analog signal / sensorPin?
