multiple input sensor
how i want to interface if i have 2 sensor as input
#define indicateLED 21
// LDR
int sensorPin = A0; // select the input pin for the ldr
unsigned int sensorValue = 0; // variable to store the value coming from the
//VIBRATE
#define SensorLED 14
#define SensorINPUT 3 //Connect the sensor to digital Pin 3 which is Interrupts 1.
unsigned char state = 0;
// LDR
pinMode(15, OUTPUT);
//VIBRATE
pinMode(SensorLED, OUTPUT);
pinMode(SensorINPUT, INPUT);
attachInterrupt(1, blink, FALLING);// Trigger the blink function when the falling edge is detected
if ((sensorValue<100) || (state!=0))
//digitalWrite(indicateLED,HIGH);
LDR();
VIBRATE();
//else
//digitalWrite(indicateLED,LOW);
void blink()//Interrupts function
state++;
void LDR()
//LDR
// read the value from the ldr:
sensorValue = analogRead(sensorPin);
if(sensorValue<100)
digitalWrite(15, HIGH); // set the LED on
digitalWrite(15, LOW); // set the LED on
void VIBRATE()
//VIBRATE
if(state!=0)
state = 0;
digitalWrite(SensorLED,HIGH);
digitalWrite(SensorLED,LOW);
i do like this but fail…
mashitah_radzi:
i do like this but fail..
What devices are connected to what pins?
What do you want the sketch to do?
i connect the sensor (ldr, vibration sensor) to the pin..
i want if another on of these sensor get their input (sense something), the output will triggered..
i want to built a system with multiple sensor input.. is it possible??
