Multiple Key debounce question
bit of a preface first off:
5 buttons (the volup/voldn is a rotary switch) all with a common pin (tied to +5v) and individual outputs tied to a 10k resistor then to ground. trigger is taken from the output of the switch
initial spec is to get all these buttons to toggle pin 13 ( I have a UNO) on/off.
that way I have the debounce routine correct.
using the debounce example sketch with added variables to account for the extra buttons and for some reason i cannot get it to compile.
from there I can move onto the bigger stuff below.
later spec is to get the VOLUP & VOLDN buttons to execute a serial command out to an external unit, generate a video display (I have the video overlay shield with a maxim 7456 on it) on an external display in the car.
the TUNE button to toggle between a LOW/HIGH output or via a timed loop send a serial command to an external unit
the rest are simply push buttons that toggle a transistor to ground so I still have my OE radio being controlled as it was originally
my background is in hardware so spinning a board is easy for me do this , not so much
  http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to set pin numbers:
const int buttonVD = 2;    // the number of the Vol VD pin
const int buttonVU = 4;    // the number of the VOL VU pin
const int buttonTN = 7;    // the number of the TUNE pin
const int buttonRON = 8;    // the number of the RADIO ON pin
const int buttonSRC = 12;    // the number of the AM/FM/SOURCE pin
const int ledPin = 13;      // the number of the LED pin
// Variables will change:
int ledState = LOW;         // the current state of the output pin
int buttonState;             // the current reading from the input pin
int lastButtonState = LOW;   // the previous reading from the input pin
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
  pinMode(buttonVD, INPUT);
  pinMode(buttonVU, INPUT);
  pinMode(buttonTN, INPUT);
  pinMode(buttonRON, INPUT);
  pinMode(buttonSRC, INPUT);
  pinMode(ledPin, OUTPUT);
  // set initial LED state
  digitalWrite(ledPin, ledState);
  // read the state of the switch into a local variable:
  int reading = digitalRead(buttonVD),
  int reading = digitalRead(buttonVU)
  int reading = digitalRead(buttonTN)
  int reading = digitalRead(buttonRON)
  int reading = digitalRead(buttonSRC);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH), and you've waited long enough
  // since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer than the debounce
    // delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
      // only toggle the LED if the new button state is HIGH
      if (buttonState == HIGH) {
        ledState = !ledState;
  // set the LED:
  // save the reading. Next time through the loop, it'll be the lastButtonState:
  lastButtonState = reading;
You do not need a library to debounce switches.
Just sample them every ~50ms and look for a change in state.
larryd:
clarify please.
that's what I thought that sketch did at first.
Apologies, I was looking at someone else who used a debounce library in their sketch.
chrrroger:
If you'd copy the error and put it in a post folks could see it and offer guidance.
Tell us what you think is happening here:
Is your syntax correct?
larryd:
AH! that was me trying to work out why.
thought was to set up the switches to be read. I did omit the ';' by mistake
int reading = digitalRead(buttonVD);
  int reading = digitalRead(buttonVU);
  int reading = digitalRead(buttonTN);
  int reading = digitalRead(buttonRON);
that's what I started with.
ERRORS:
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\HP PC\Documents\Arduino\HR31-audio-routines\radio-ctl-debounce\radio-ctl-debounce.ino: In function 'void loop()':
radio-ctl-debounce:64:7: error: redeclaration of 'int reading'
C:\Users\HP PC\Documents\Arduino\HR31-audio-routines\radio-ctl-debounce\radio-ctl-debounce.ino:63:7: note: 'int reading' previously declared here
radio-ctl-debounce:65:7: error: redeclaration of 'int reading'
radio-ctl-debounce:66:7: error: redeclaration of 'int reading'
radio-ctl-debounce:67:7: error: redeclaration of 'int reading'
exit status 1
option enabled in File -> Preferences.
that may be the multiple times I tried to compile it. the error is constant though.
Tell us what you think is happening for each line of code.
BTW, “ error: redeclaration of 'int reading'” Dose this give you a hint?
"int reading;" declares an integer variable with the name 'reading'.
The " = digitalRead(buttonVU)" initializes the variable with the value returned by the function call.
First, you can't declare the same variable more then once in the same block:
Second, you can't assign a variable more than one value so this bit of code is equivalent to:
thanks for the help. still getting my head around a lot of this.
will keep fiddling with it.
Here are some more hints:
First read this: loop() - Arduino Reference to understand setup() and loop().
I saw you were defining and initializing variable in your void loop().
First have your setup which runs once:
Then your loop which runs forever: (note, I’m not defining reading, just assigning a value to it)
As to debouncing: my experience is that if the button has been consistent for 30ms, (perhaps read every 10ms and sample 3 times) then you can use it. If it changes then start sampling again.
You can also put the variable definition before the setup(). See this example:
https://www.arduino.cc/reference/en/language/functions/digital-io/digitalread/
rjj100:
Nope, that won't work. If you declare 'reading' as a local variable in setup() you can't use that variable in loop().
Since the variable 'reading' is never used outside loop() you can, and should, make it local to loop():
  int reading ;
If the value 'reading' is shared across multiple functions, make it global:
int Reading;  // Globals default to 0
  Reading = digitalRead(buttonVD);
Note that I use an initial capital 'R' to help keep track of which variables are global.
Right, should put it before setup. Thats how I always do it. My mistake.
