Multiple LED + Neopixel
I'm sorry, but I have NO idea how to code.
I'm looking to turn 9 LEDs on sequentially, then run 3 neopixels with random colour outputs.
Ive got two working codes, but I can not combine them.
Either the NEOPixels blink, or the 9 white LEDS turn on sequentually.
Any coders here able to help a total noob please?
#define PIN 11  	// input pin Neopixel is attached to
#define NUMPIXELS      3 // number of neopixels in strip
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 10; // timing delay in milliseconds
int redColor = 0;
int greenColor = 0;
int blueColor = 0;
void setup1() { // Initialize the NeoPixel library.
  pixels.begin();
void loop1() {
  setColor();
  for (int i=0; i < NUMPIXELS; i++) {
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(redColor, greenColor, blueColor));
    // This sends the updated pixel color to the hardware.
    pixels.show();
    // Delay for a period of time (in milliseconds).
    delay(delayval);
// setColor()
// picks random values to set for RGB
void setColor(){
  redColor = random(0, 0);
  greenColor = random(100,255);
  blueColor = random(200, 255);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
// analogWrite(3, brightness);
ledStart();
engineStartSection1(11);
engineStartSection2(11);
engineStartSection4(11);
delay(2000);
digitalWrite(10,HIGH);
// engine4();
void engineStartSection1(int led){
for(int i = 0; i < 100; i++){
analogWrite(led, i);
delay(40);
delay(50);
for(int i = 100; i > 11; i--){
delay(40);
void engineStartSection2(int led){
for(int i = 11; i < 250; i++){
delay(5);
delay(100);
for(int i = 250; i > 10; i--){
delay(30);
void engineStartSection4(int led){
for(int i = 50; i < 200; i++){
delay(10);
delay(100);
for(int i = 250; i > 200; i--){
delay(10);
void engine4(){
while(true){
int randomNumber = random(150,230);
analogWrite(11, randomNumber);
delay(100);
void ledStart(){
for(int i = 2; i < 10; i++){
digitalWrite(i,HIGH);
}`Preformatted text`
Welcome to the forum.
Which Arduino board do you use ?
Are 3 NeoPixel leds connected to pin 11 ?
Are the pins 2 up to 10 used for 9 white leds ?
Is nothing else connected to the Arduino board ?
When writing a sequence in code with delay(), then it is not possible to do something else at the same time. That is no problem if you first turn on the 9 white leds sequentially and after that put a random color on the NeoPixel leds.
Uno R3, but hoping to rum them on a Nano for a model.
Yes
Yes
Nothing else is connected.
I tried the NEOPixel code after the 9 LEDs, but the code just wouldnt work. Sorry I didnt post that one here as I scrapped it and just posted the individual sections. I had the 9 light up in sequence, then called up a rewritten Engine4 loop that reported no errors, but didn't light up the NEO's.
Your sketch raises some questions and I didn't know what to do with it.
Is it okay if I give something that works, then you can continue with my sketch.
// 9 March 2022
// For: https://forum.arduino.cc/t/multiple-led-neopixel/967303
const int ledPins[9] = { 2, 3, 4, 5, 6, 7, 8, 9, 10};
int delayval = 100; // timing delay in milliseconds
  // Nine white leds
  for( int i=0; i<9; i++)
    pinMode( ledPins[i], OUTPUT);
  // Three Neopixel leds
  pixels.begin();
  // Nine white leds
    digitalWrite( ledPins[i], HIGH);      // turn led on
    delay( 150);
  for( int j=0; j<20; j++)        // a number of times a random color
      int redColor   = random( 0, 256);
      int greenColor = random( 0, 256);
      int blueColor  = random( 0, 256);
      pixels.show();
      delay(delayval);
  // Nine white leds
  for( int i=8; i>=0; i--)
    digitalWrite( ledPins[i], LOW);      // turn led off
    delay( 150);
  delay( 500);
Ask what you don't understand.
I put that sketch in Wokwi simulation:
To continue with my Wokwi project, log in at Wokwi and save it to your own projects with "Save a copy". Then you (or someone else) can continue with it and give a link to the new Wokwi project, and someone else can continue with that.
void setup1()
void loop1()
Maybe you hoped that setup() and setup1() and then loop() and loop1() would be running at the same time, in parallel? Unfortunately not. setup() and loop() will be executed, but setup1() and loop1() are never called and will never execute.
Thank you very much.
I used this in TinkerCAD and it ran my simulator perfectly. I've also run it on my UNO and Breadboard, and its great.
I've nulled out the LED off sequence so that they remain on.
The code works perfectly. Thank you very much.
