So the rows are represented the frames/seconds and the columns represented the leds state - led 1(index 0) is the far most right and led 64 (index 63) is far most left.
can I make it a rows of only 60 bits (as the number of leds I will use) and not 64 ?
so if my sequence is 5 minutes I gonna have an array of 300 lines and 60 columns?
edit:
so with the memory it taken for 300 hundreds line of 64 bit I actually make a sequence of 15 minutes (1500 lines), right?
you could but I will expand it to 64 anyway as I will make an generic example with 64 LEDs. And it will have no effect on the memory, as each "line" occupies 64bit, regardless if you just define 0b0 or 60bit or full on with 0xFFFFFFFFFFFFFFFF
yes. 300 lines at 1 second will give you a playtime of 5 minutes with 60 LEDs (64 are possible).
let's try it, you could do the math on your own . There are some limits with low 64K (near/far) but this is not the point currently.
I was wandering if I can change the variable 'interval' to be different values in different frames/lines
for example between frame/line 1 to 10 to have an interval of 500 milliseconds and between lines 11 - 22 to have an interval of 1000 milliseconds , then between lines 100 - 150 to have a interval of 250 milliseconds.
Can I do so?
I guess I need to count some how the line I'm in and if the count is passed a specific line then change the interval to a different number.. possible?
edit:
something like that:
#endif
actualPattern++; // switch to next pattern for the next iteration
if (actualPattern >= totalNoPattern)
actualPattern = 0; // wrap around
if (actualPattern > 10 && actualPattern < 20)
interval = 200;
previousMillis = millis();
edit: I just needed to change the interval to be only int without a const and it seems to work fine!
make the interval a variable (remove the const)
ad some ifs to change the interval, someting like
if (actualPattern == 11) interval = 1000;
else if (actualPattern == 100) interval = 250;
else if (actualPattern == 0) interval = 100; // don't forget to switch back to your start value...
and you don't need an int. int is signed and your interval will never get negative.
can I add a counter that counts how many leds are in on states at the same time and keep track of it? (adding and removing from and to count)
I would like to make sure no more then 18 leds will be on at the same time so I can drew from each led 10mA instead of 3mA I'm drawing right now. (due to arduino max 200mA current limitation)
make a counter variable and increase its value in the if true (when you switch on a LED).
After the for loop you know how many IOs were set.
A better way would be a test function to be called once in setup, highlighting lines with to many LEDs. You do the correction of the array and upload a new sketch.
Make us proud of your learnings and show that you have understood the program.
the precompiler will replace everywhere in the sketch the term DEBUG_UART with a 1
now if you see a
#if DEBUG_UART
the precompiler will get #if 1
which translates to a "true" and will keep the lines in the source code.
if you change the DEBUG_UART to 0, the precompiler will "delete" the lines between #if and #endif - your program gets smaller because there is no need to print.
This explanation might not be 100% accurate but hopefully understandable.
I manage to count how many leds on using 'ledCount++;' right after the 'digitalWrite (ledPin[I], HIGH);'
but then when I'm using 'ledCount--;' right after the 'digitalWrite(ledPin[I], LOW);' it count all the off leds.
I needs somehow to count only the leds that were previously on .
I might not explain myself well
I want to count how many leds are on in a given time
so if in my first frame I had 2 leds on my counter will show 2.
in the next frame I have also 2 leds on so my counter should also show 2.
int the next frame I have 0 leds on so my count will show 0
and in the frame after I will have 10 leds on so my counter should show 10.
the counter will count the number of led are on at the same time in any given frame and will changed according to that.
void runSequence()
static uint32_t previousMillis = 0;
static size_t actualPattern = 0;
byte noOfactiveLeds = 0; // create a variable
if (millis() - previousMillis >= interval)
// lets copy the actual pattern from progmem to a temporary local variable in SRAM
patternType temp;
memcpy_P(&temp, &pattern[actualPattern], sizeof(patternType));
// now check each bit for each LED if it is 0 or 1 and switch the pin accordingly
for (size_t i = 0; i < totalNoPins; i++)
if (temp & ((patternType)1 << i)) {
#if DEBUG_UART
Serial.print(F("X"));
#endif
digitalWrite(ledPin[i], HIGH);
noOfactiveLeds++; // increase counter
else {
#if DEBUG_UART
Serial.print(F(" "));
#endif
digitalWrite(ledPin[i], LOW);
#if DEBUG_UART
Serial.print(F(" active LEDs=")); // NEW
Serial.print(noOfactiveLeds); // NEW
Serial.print(F(" - "));
Serial.println(actualPattern);
#endif
