Multiple LED's blink without delay
I have an array of 11 pins. I am trying to get a sequence going where the LEDs blink on and off from the outside in to the middle.
0 - - - - - - - - - 0
  • 0 - - - - - - - 0 -
    • 0 - - - - - 0 - -
      • 0 - - - 0 - - -
        • 0 - 0 - - - -
          • 0 - - - - -
0 = LED on.
I can do this with delays by coding the individual pins manually.
I have been using the blink without delay example.
The problem I am having is the LED board I am using is inverted
So HIGH for the LED’s off and LOW for the LED’s on.
The problem is every second LED is turning on one at a time and not blinking. Once these are all on, the other LED’s start blinking. It does not seem to be incrementing through my arrays 1 pin at a time.
My code is:
int index = 0;
int ledPins[] = {
  9,8,7,6,5,4,3,2,14,15,16};
int ledState = HIGH;
unsigned long previousMillis = millis();
long interval = 1000;
int x = 0;
int test1L[] = {
  9,8,7,6,5};
int test1R[] = {
  16,15,14,2,3};
  Serial.begin(19200);
  for(index = 0; index < 11; index++)
    pinMode(ledPins[index], OUTPUT);
  for(int i = 0; i < 11; i++)
    digitalWrite(ledPins[i], HIGH);
  analogWrite(11, 0);
  analogWrite(12, 0);
  analogWrite(13, 255);
  if(currentMillis - previousMillis > interval)
    if (ledState == HIGH)
      ledState = LOW;
      ledState = HIGH;
    analogWrite(11, 0);
    analogWrite(12, 0);
    digitalWrite(test1L[x], ledState);
    digitalWrite(test1R[x], ledState);
    x++; //increment x pins
  if(x > 4)
    digitalWrite(4, ledState); //blink middle LED
    x = 0;
simplified the code a bit, find the 7 differences :wink:
int ledPins[] = {
unsigned long previousMillis = 0;
unsigned long interval = 1000;
int x = 0;
  for(int i= 0; i < 11; i++)
    pinMode(ledPins[i], OUTPUT);
  if (currentMillis - previousMillis >= interval)
    // switch OFF
    digitalWrite(ledPins[x], HIGH);       // left
    digitalWrite(ledPins[9-x], HIGH);  // right
     x++;
     if (x == 4) x = 0;
    // switch ON
    digitalWrite(ledPins[x], LOW);       // left
    digitalWrite(ledPins[9-x], LOW);  // right
    digitalWrite(4, !digitalRead(4));  //invert middle LED every step
