Dear all,
I have a MP3 shield and a DMX shield. Now I want to combine these on one Arduino. Thus play music and use the DMX.
For now i used the following code (i deleted some code from the original code):
This is an example for the Adafruit VS1053 Codec Breakout
Designed specifically to work with the Adafruit VS1053 Codec Breakout
----> https://www.adafruit.com/products/1381
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// These are the pins used for the breakout example
#define BREAKOUT_RESET 8 // VS1053 reset pin (output)
#define BREAKOUT_CS 6 // VS1053 chip select pin (output)
#define BREAKOUT_DCS 7 // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 9 // VS1053 chip select pin (output)
#define SHIELD_DCS 7 // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 9 // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 5 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
// create breakout-example object!
Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
// create shield-example object!
//Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
Serial.println("Adafruit VS1053 Simple Test");
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found"));
if (!SD.begin(CARDCS)) {
Serial.println(F("SD failed, or not present"));
while (1); // don't do anything more
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(1,1);
// audio playing
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT); // DREQ int
// Play one file, don't return until complete
Serial.println(F("Playing track 001"));
musicPlayer.playFullFile("/1.mp3");
// Play another file in the background, REQUIRES interrupts!
Serial.println(F("Playing track 002"));
musicPlayer.startPlayingFile("/2.mp3");
// File is playing in the background
if (musicPlayer.stopped()) {
Serial.println("Done playing music");
while (1) {
delay(10); // we're done! do nothing...
if (Serial.available()) {
char c = Serial.read();
// if we get an 's' on the serial console, stop!
if (c == 's') {
musicPlayer.stopPlaying();
// if we get an 'p' on the serial console, pause/unpause!
if (c == 'p') {
if (! musicPlayer.paused()) {
Serial.println("Paused");
musicPlayer.pausePlaying(true);
Serial.println("Resumed");
musicPlayer.pausePlaying(false);
delay(100);
I want to play the music (1.mp3) and then give a white light. Thus, I want to combine this with the following code:
#include <Conceptinetics.h>
DMX_Master dmx_master ( 100 , 2 );
dmx_master.enable ();
dmx_master.setChannelValue ( 32, 255 ); // MH1 white full brightness (channel 32)
dmx_master.setChannelValue ( 36, 255); // MH1 White
I'll tried multiple things like combining the code however this results in a compiling error if i use both libaries.
Does somebody know what i did wrong?
