Multiple libaries were found for "SoftwareSerial.h"
Hi everyone,
I want to code a programm that plays sounds with DFPlayer and a small speaker.
First I found one sample code from the internet that I want to change. It works in the tutorial, but when I'm trying to upload it on my Arduino I get some errors:
Arduino: 1.8.10 (Windows 8.1), Board: "Arduino Uno"
C:\Users\User\Desktop\Joystick\DFPlayer-test\DFPlayer-test.ino: In function 'void setup()':
DFPlayer-test:28:1: error: 'playFirst' was not declared in this scope
playFirst();
C:\Users\User\Desktop\Joystick\DFPlayer-test\DFPlayer-test.ino: In function 'void loop()':
DFPlayer-test:40:7: error: 'pause' was not declared in this scope
   pause();
DFPlayer-test:45:7: error: 'play' was not declared in this scope
   play();
C:\Users\User\Desktop\Joystick\DFPlayer-test\DFPlayer-test.ino:45:7: note: suggested alternative: 'delay'
   play();
   delay
DFPlayer-test:54:7: error: 'playNext' was not declared in this scope
   playNext();
DFPlayer-test:62:7: error: 'playPrevious' was not declared in this scope
   playPrevious();
C:\Users\User\Desktop\Joystick\DFPlayer-test\DFPlayer-test.ino:62:7: note: suggested alternative: 'buttonPrevious'
   playPrevious();
   buttonPrevious
Multiple libraries were found for "SoftwareSerial.h"
Used: C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\SoftwareSerial
exit status 1
option enabled in File -> Preferences.
The code is:
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11);
#define Start_Byte 0x7E
#define Version_Byte 0xFF
#define Command_Length 0x06
#define End_Byte 0xEF
#define Acknowledge 0x00
#define ACTIVATED LOW
int buttonNext = 2;
int buttonPause = 3;
int buttonPrevious = 4;
boolean isPlaying = false;
void setup () {
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause,HIGH);
pinMode(buttonNext, INPUT);
digitalWrite(buttonNext,HIGH);
pinMode(buttonPrevious, INPUT);
digitalWrite(buttonPrevious,HIGH);
mySerial.begin (9600);
playFirst();
isPlaying = true;
void loop () {
if (digitalRead(buttonPause) == ACTIVATED)
if(isPlaying)
pause();
isPlaying = false;
}else
isPlaying = true;
play();
if (digitalRead(buttonNext) == ACTIVATED)
if(isPlaying)
playNext();
if (digitalRead(buttonPrevious) == ACTIVATED)
if(isPlaying)
playPrevious();
If you've got ideas how I can make this code work, I'll be thankful.
Best regards
Kris
You are missing a #include of some DFPlayer library which contains all the functions you are calling in your code.
The multiple libraries for SoftwareSerial.h is not the problem.
Read the forum guidelines to see how to post code.
Use the IDE autoformat tool (ctrl-t or Tools, Auto Format) to indent the code for readability before posting code.
This specific "Multiple libraries were found for" message was the result of a bug:
https://github.com/arduino/Arduino/issues/9601
It was fixed a couple of years ago, but you're using a super outdated version of the Arduino IDE.
You'll know a legitimate "Multiple libraries were found for" message because it will list the paths of each of the multiple libraries. When you see only a single path, that message results from the bug.
I included "DFRobotDFPlayerMini.h" and defined RX and TX pins and now everything works normally.
Thank you!
Excuse me! I'm new here, I didn't know that.
