Multiple libraries were found for "BlynkSimpleEsp8266.h"
hi guys am trying to use Blynk and arduino uno and ESP8266, after writting this code got from the Blynk website :
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
Download latest Blynk library here:
Blynk is a platform with iOS and Android apps to control
Arduino, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your
projects by simply dragging and dropping widgets.
Downloads, docs, tutorials: http://www.blynk.cc
Sketch generator: http://examples.blynk.cc
Blynk community: http://community.blynk.cc
Follow us: Blynk
http://twitter.com/blynk_app
Blynk library is licensed under MIT license
This example code is in public domain.
You’ll need:
  • Blynk App (download from AppStore or Google Play)
  • ESP8266 board
  • Decide how to connect to Blynk
    (USB, Ethernet, Wi-Fi, Bluetooth, ...)
There is a bunch of great example sketches included to show you how to get
started. Think of them as LEGO bricks and combine them as you wish.
For example, take the Ethernet Shield sketch and combine it with the
Servo example, or choose a USB sketch and add a code from SendData
example.
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <BlynkSimpleEsp8266.h> <------------- the problem is here why is it in black
#include <ESP8266WiFi.h> <------------- in red color
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "vUQoaIcZWGIppDbc6E0jbeumP6K-c5xR";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "D-Link_Mounir";
char pass[] = "YAFFATAH";
// Debug console
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
Blynk.run();
// You can inject your own code or combine it with other sketches.
// Check other examples on how to communicate with Blynk. Remember
// to avoid delay() function!
i got the error message :
In file included from C:\Users\pavion\Documents\Arduino\blynk_try-3\blynk_try-3.ino:1:0:
Used: C:\Users\pavion\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
C:\Users\pavion\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/BlynkSimpleEsp8266.h:18:21: fatal error: version.h: No such file or directory
Not used: C:\Users\pavion\Documents\Arduino\libraries\arduino_787048
#include <version.h>
Not used: C:\Users\pavion\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Blynk
Not used: C:\Users\pavion\Documents\Arduino\libraries\Blynk
compilation terminated.
exit status 1
Error compiling for board Generic ESP8266 Module.
