Open CR
https://github.com/ROBOTIS-GIT/OpenCR
OpeenCM
https://github.com/ROBOTIS-GIT/OpenCM9.04
They both have their own ros_lib and the sketch
#include "ModbusBLVmotor.h"
#include <ros.h>
#include <sensor_msgs/Imu.h>
#include <sensor_msgs/MagneticField.h>
#include <RTOS.h>
#include <std_msgs/Int32.h>
#include <tf/tf.h>
#include <tf/transform_broadcaster.h>
#include "lino_velocities.h"
#include "geometry_msgs/Twist.h"
#include "lino_imu.h"
#include "Kinematics.h"
#include <IMU.h>
#define LINO_BASE DIFFERENTIAL_DRIVE // 2WD and Tracked robot w/ 2 motors
#define MAX_RPM 100 // motor's maximum RPM
#define WHEEL_DIAMETER 0.150 // wheel's diameter in meters
//#define LR_WHEELS_DISTANCE 0.395 // distance between left and right wheels 0.800
//#define LR_WHEELS_DISTANCE 0.538 // distance between left and right wheels 0.800
#define LR_WHEELS_DISTANCE 0.30 // distance between left and right wheels 0.800
#define FR_WHEELS_DISTANCE 0.30 // distance between front and rear wheels. Ignore this if you're on 2WD/ACKERMANN
#define USE_MPU9250_IMU
#define ACCEL_FACTOR 0.000598550415 // (ADC_Value / Scale) * 9.80665 => Range : +- 2[g] \
// Scale : +- 16384
#define GYRO_FACTOR 0.0010642 // (ADC_Value/Scale) * (pi/180) => Range : +- 2000[deg/s] \
// Scale : +- 16.4[deg/s]
#define MAG_FACTOR 15e-8
#define COMMAND_RATE 30
cIMU IMU;
Kinematics kinematics(Kinematics::LINO_BASE, MAX_RPM, WHEEL_DIAMETER, FR_WHEELS_DISTANCE, LR_WHEELS_DISTANCE);
int led_state = 0;
float g_req_linear_vel_x = 0;
float g_req_linear_vel_y = 0;
float g_req_angular_vel_z = 0;
unsigned long g_prev_command_time = 0;
int currentLeftWheelRPM;
int currentRightWheelRPM;
std_msgs::Int32 rpmLeft;
std_msgs::Int32 rpmRight;
void commandCallback(const geometry_msgs::Twist &cmd_msg);
void moveBase();
void waitForSerialLink(bool isConnected);
ros::NodeHandle nh;
geometry_msgs::TransformStamped tfs_msg;
tf::TransformBroadcaster tfbroadcaster;
ModbusBLVmotor md;
ros::Subscriber<geometry_msgs::Twist> cmd_sub("cmd_vel", commandCallback);
/*lino_msgs::Imu raw_imu_msg;
ros::Publisher raw_imu_pub("raw_imu", &raw_imu_msg);
//***** IMU Pub declear ****
sensor_msgs::Imu imu;
ros::Publisher imu_pub("/imu/data", &imu);
sensor_msgs::MagneticField raw_data_mag;
ros::Publisher raw_mag_data_pub("/imu/mag", &raw_data_mag);
lino_msgs::Velocities raw_vel_msg;
ros::Publisher raw_vel_pub("raw_vel", &raw_vel_msg);
ros::Publisher rpmLeft_pub("rpmLeft", &rpmLeft);
ros::Publisher rpmRight_pub("rpmRight", &rpmRight);
int led_pin = 13;
unsigned long prev_update_time_m1 = 0;
unsigned long prev_update_time_m2 = 0;
unsigned long pulseRPM1 = 0;
unsigned long pulseRPM2 = 0;
unsigned long prev_update_time_M1 = 0;
unsigned long prev_update_time_M2 = 0;
unsigned long prev_encoder_ticks_M1 = 0;
unsigned long prev_encoder_ticks_M2 = 0;
int counts_per_rev_ = 15;
osThreadId thread_command;
osThreadId thread_odom;
osThreadId thread_imu;
void m1Pulse(void) {
unsigned long current_time_m1 = micros();
unsigned long dt = current_time_m1 - prev_update_time_m1;
prev_update_time_m1 = micros();
float freq_m1 = 1 / (dt * 0.000001);
pulseRPM1++;
//Serial.print("m1 = ");
//Serial.println(freq_m1);
void m2Pulse(void) {
unsigned long current_time_m2 = micros();
unsigned long dt = current_time_m2 - prev_update_time_m2;
prev_update_time_m2 = micros();
float freq_m2 = 1 / (dt * 0.000001);
pulseRPM2++;
//Serial.print("m2 = ");
//Serial.println(freq_m2);
int getRPM1() {
unsigned long encoder_ticks = pulseRPM1;
//this function calculates the motor's RPM based on encoder ticks and delta time
unsigned long current_time = millis();
unsigned long dt = current_time - prev_update_time_M1;
//convert the time from milliseconds to minutes
double dtm = (double)dt / 60000.0;
double delta_ticks = encoder_ticks - prev_encoder_ticks_M1;
//calculate wheel's speed (RPM)
prev_update_time_M1 = current_time;
prev_encoder_ticks_M1 = encoder_ticks;
return ((delta_ticks / counts_per_rev_) / dtm) / 60;
int getRPM2() {
unsigned long encoder_ticks = pulseRPM2;
unsigned long dt = current_time - prev_update_time_M2;
double delta_ticks = encoder_ticks - prev_encoder_ticks_M2;
prev_update_time_M2 = current_time;
prev_encoder_ticks_M2 = encoder_ticks;
void setLeftRPM(int rpm) {
if (rpm < 0) {
//M1_dir = 1;
currentLeftWheelRPM = -1 * getRPM1();
//M1_dir = 0;
currentLeftWheelRPM = getRPM1();
md.setM1Speed(rpm);
void setRightRPM(int rpm) {
if (rpm < 0) {
//M2_dir = 1;
currentRightWheelRPM = -1 * getRPM2();
//M2_dir = 0;
currentRightWheelRPM = getRPM2();
md.setM2Speed(rpm);
static void Thread_command(void const *argument) {
(void)argument;
static unsigned long prev_control_time = 0;
for (;;) {
if ((millis() - prev_control_time) >= (1000 / COMMAND_RATE)) {
Kinematics::rpm req_rpm = kinematics.getRPM(g_req_linear_vel_x, g_req_linear_vel_y, g_req_angular_vel_z);
setLeftRPM(req_rpm.motor1);
setRightRPM(req_rpm.motor2);
digitalWrite(led_pin, (led_state) ? HIGH : LOW);
led_state = !led_state;
//sprintf (buffer, "Encoder FrontLeft : %i Encoder FrontRight : %i ", currentLeftWheelRPM, currentRightWheelRPM);
//nh.loginfo(buffer);
prev_control_time = millis();
nh.spinOnce();
// Wait the serial link time to process
waitForSerialLink(nh.connected());
static void Thread_odom(void const *argument) {
(void)argument;
static unsigned long prev_odom_time = 0;
Kinematics::velocities current_vel;
for (;;) {
if ((millis() - prev_odom_time) >= (1000 / COMMAND_RATE)) {
int current_rpm1 = currentLeftWheelRPM; //rightWheel.getRPM();
int current_rpm2 = currentRightWheelRPM; //leftWheel.getRPM();
int current_rpm3 = 0;
int current_rpm4 = 0;
rpmLeft.data = currentLeftWheelRPM;
rpmRight.data = currentRightWheelRPM;
rpmLeft_pub.publish(&rpmLeft);
rpmRight_pub.publish(&rpmRight);
current_vel = kinematics.getVelocities(current_rpm1, current_rpm2, current_rpm3, current_rpm4);
//current_vel = kinematics.getVelocities(50, 50, 0, 0);
//pass velocities to publisher object
raw_vel_msg.linear_x = current_vel.linear_x;
raw_vel_msg.linear_y = current_vel.linear_y;
raw_vel_msg.angular_z = current_vel.angular_z;
//publish raw_vel_msg
raw_vel_pub.publish(&raw_vel_msg);
prev_odom_time = millis();
nh.spinOnce();
static void Thread_imu(void const *argument) {
(void)argument;
static unsigned long prev_imu_time = 0;
for (;;) {
if ((millis() - prev_imu_time) >= 1000 / 50) {
IMU.update();
/* raw_imu_msg.linear_acceleration.x = IMU.SEN.accADC[0] * ACCEL_FACTOR;
raw_imu_msg.linear_acceleration.y = IMU.SEN.accADC[1] * ACCEL_FACTOR;
raw_imu_msg.linear_acceleration.z = IMU.SEN.accADC[2] * ACCEL_FACTOR;
raw_imu_msg.angular_velocity.x = IMU.SEN.gyroADC[0] * GYRO_FACTOR;
raw_imu_msg.angular_velocity.y = IMU.SEN.gyroADC[1] * GYRO_FACTOR;
raw_imu_msg.angular_velocity.z = IMU.SEN.gyroADC[2] * GYRO_FACTOR;
raw_imu_msg.magnetic_field.x = IMU.SEN.magADC[0] * MAG_FACTOR;
raw_imu_msg.magnetic_field.y = IMU.SEN.magADC[1] * MAG_FACTOR;
raw_imu_msg.magnetic_field.z = IMU.SEN.magADC[2] * MAG_FACTOR;
raw_imu_pub.publish(&raw_imu_msg);*/
imu.angular_velocity.x = IMU.SEN.gyroADC[0] * GYRO_FACTOR;
imu.angular_velocity.y = IMU.SEN.gyroADC[1] * GYRO_FACTOR;
imu.angular_velocity.z = IMU.SEN.gyroADC[2] * GYRO_FACTOR;
imu.angular_velocity_covariance[0] = 0.02;
imu.angular_velocity_covariance[1] = 0;
imu.angular_velocity_covariance[2] = 0;
imu.angular_velocity_covariance[3] = 0;
imu.angular_velocity_covariance[4] = 0.02;
imu.angular_velocity_covariance[5] = 0;
imu.angular_velocity_covariance[6] = 0;
imu.angular_velocity_covariance[7] = 0;
imu.angular_velocity_covariance[8] = 0.02;
imu.linear_acceleration.x = IMU.SEN.accADC[0] * ACCEL_FACTOR;
imu.linear_acceleration.y = IMU.SEN.accADC[1] * ACCEL_FACTOR;
imu.linear_acceleration.z = IMU.SEN.accADC[2] * ACCEL_FACTOR;
imu.linear_acceleration_covariance[0] = 0.04;
imu.linear_acceleration_covariance[1] = 0;
imu.linear_acceleration_covariance[2] = 0;
imu.linear_acceleration_covariance[3] = 0;
imu.linear_acceleration_covariance[4] = 0.04;
imu.linear_acceleration_covariance[5] = 0;
imu.linear_acceleration_covariance[6] = 0;
imu.linear_acceleration_covariance[7] = 0;
imu.linear_acceleration_covariance[8] = 0.04;
imu.orientation.w = IMU.quat[0];
imu.orientation.x = IMU.quat[1];
imu.orientation.y = IMU.quat[2];
imu.orientation.z = IMU.quat[3];
imu.orientation_covariance[0] = 0.0025;
imu.orientation_covariance[1] = 0;
imu.orientation_covariance[2] = 0;
imu.orientation_covariance[3] = 0;
imu.orientation_covariance[4] = 0.0025;
imu.orientation_covariance[5] = 0;
imu.orientation_covariance[6] = 0;
imu.orientation_covariance[7] = 0;
imu.orientation_covariance[8] = 0.0025;
imu.header.stamp = rosNow();
imu.header.frame_id = "imu_link"; //imu_frame_id;
imu_pub.publish(&imu);
raw_data_mag.magnetic_field.x = IMU.SEN.magADC[0] * MAG_FACTOR;
raw_data_mag.magnetic_field.y = IMU.SEN.magADC[1] * MAG_FACTOR;
raw_data_mag.magnetic_field.z = IMU.SEN.magADC[2] * MAG_FACTOR;
raw_data_mag.magnetic_field_covariance[0] = 0.0048;
raw_data_mag.magnetic_field_covariance[1] = 0;
raw_data_mag.magnetic_field_covariance[2] = 0;
raw_data_mag.magnetic_field_covariance[3] = 0;
raw_data_mag.magnetic_field_covariance[4] = 0.0048;
raw_data_mag.magnetic_field_covariance[5] = 0;
raw_data_mag.magnetic_field_covariance[6] = 0;
raw_data_mag.magnetic_field_covariance[7] = 0;
raw_data_mag.magnetic_field_covariance[8] = 0.0048;
raw_data_mag.header.stamp = rosNow();
raw_data_mag.header.frame_id = "imu_link `"; //mag_frame_id;
raw_mag_data_pub.publish(&raw_data_mag);
prev_imu_time = millis();
nh.spinOnce();
pinMode(led_pin, OUTPUT);
pinMode(BDPIN_LED_USER_1, OUTPUT);
nh.initNode();
nh.getHardware()->setBaud(57600);
nh.subscribe(cmd_sub);
nh.advertise(raw_vel_pub);
//nh.advertise(raw_imu_pub);
nh.advertise(imu_pub);
nh.advertise(raw_mag_data_pub);
nh.advertise(rpmLeft_pub);
nh.advertise(rpmRight_pub);
//Serial.begin(115200);
//Serial.println("Start");
pinMode(7, INPUT); //set Arduino Pin 2 as input with pull-down
attachInterrupt(3, m1Pulse, RISING);
pinMode(8, INPUT); //set Arduino Pin 2 as input with pull-down
attachInterrupt(4, m2Pulse, RISING);
md.init();
IMU.begin();
calibrationGyro();
// define thread
osThreadDef(THREAD_NAME_COMMAND, Thread_command, osPriorityNormal, 0, 1024);
osThreadDef(THREAD_NAME_ODOM, Thread_odom, osPriorityNormal, 0, 1024);
osThreadDef(THREAD_NAME_IMU, Thread_imu, osPriorityNormal, 0, 1024);
// create thread
thread_command = osThreadCreate(osThread(THREAD_NAME_COMMAND), NULL);
thread_odom = osThreadCreate(osThread(THREAD_NAME_ODOM), NULL);
thread_imu = osThreadCreate(osThread(THREAD_NAME_IMU), NULL);
// start kernel
osKernelStart();
* Start Gyro Calibration
void calibrationGyro() {
uint32_t pre_time;
uint32_t t_time;
//const uint8_t led_ros_connect = 3;
IMU.SEN.gyro_cali_start();
t_time = millis();
pre_time = millis();
while (!IMU.SEN.gyro_cali_get_done()) {
IMU.update();
if (millis() - pre_time > 20000) {
if (millis() - t_time > 100) {
t_time = millis();
//setLedToggle(led_ros_connect);
digitalWrite(BDPIN_LED_USER_1, !digitalRead(BDPIN_LED_USER_1));
digitalWrite(BDPIN_LED_USER_1, HIGH);
void updateGyroCali(bool isConnected) {
static bool isEnded = false;
char log_msg[50];
if (nh.connected()) {
if (isEnded == false) {
sprintf(log_msg, "Start Calibration of Gyro");
nh.loginfo(log_msg);
calibrationGyro();
sprintf(log_msg, "Calibration End");
isEnded = true;
isEnded = false;
* ros::Time::now() implementation
ros::Time rosNow() {
return nh.now();
//osDelay(100);
//digitalWrite(led_pin, HIGH); // set to as HIGH LED is turn-off
//delay(200); // Wait for 0.1 second
//digitalWrite(led_pin, LOW); // set to as LOW LED is turn-on
//md.setM1Speed(40);
//delay(2000);
//md.setM2Speed(40);
//delay(2000);
//md.setM2Speed(0);
//delay(2000);
//Serial.println("5555");
//Serial2.print("66656");
//this block drives the robot based on defined rate
//moveBase();
//digitalWrite(led_pin, (led_state) ? HIGH : LOW);
//led_state = !led_state;
//updateGyroCali(nh.connected());
nh.spinOnce();
void stopBase() {
md.setM1Speed(0);
//delay(2000);
md.setM2Speed(0);
void moveBase() {
/*int current_rpm1 = currentLeftWheelRPM; //rightWheel.getRPM();
raw_vel_pub.publish(&raw_vel_msg);*/
* Wait for Serial Link
void waitForSerialLink(bool isConnected) {
static bool wait_flag = false;
if (isConnected) {
if (wait_flag == false) {
delay(10);
wait_flag = true;
wait_flag = false;
void commandCallback(const geometry_msgs::Twist &cmd_msg) {
//char buffer[40];
g_req_linear_vel_x = cmd_msg.linear.x;
g_req_linear_vel_y = cmd_msg.linear.y;
g_req_angular_vel_z = cmd_msg.angular.z;
//moveBase();
g_prev_command_time = millis();
//nh.spinOnce();
//waitForSerialLink(nh.connected());
