Multiple libraries were found for ........
I am currently try to upload this code into my NodeMCU ESP8266 with GPS Flight Module. My purpose is to set the NodeMCU to sent longitude and latitude data directly into my firebase to create a real-time tracking device. Currently it shows errors of Multiple libraries were found for (All libraries included). Please help me as i find no answer for this issues.
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
static const int RXPin = D6, TXPin = D7; //TX //RX
static const uint32_t GPSBaud = 9600;
// masukkan ssid dan password hotspot
const char* ssid     = "xxxxxxxxxxxxxx";
const char* password = "xxxxxxxxxxxxx";
#define FIREBASE_HOST "xxxxxxxxxxxxxxxxx"
#define FIREBASE_AUTH "xxxxxxxxxxxxxxxx"
TinyGPSPlus gps;
WiFiClient  client;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
  ss.begin(GPSBaud);
  Serial.println(F("Testing GPS1 "));
  Serial.println(F("Testing GPS 2"));
  Serial.print(F("Testing GPS 3 ")); Serial.println(TinyGPSPlus::libraryVersion());
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
   Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.print("Netmask: ");
  Serial.println(WiFi.subnetMask());
  Serial.print("Gateway: ");
  Serial.println(WiFi.gatewayIP());
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
  // This sketch displays information every time a new sentence is correctly encoded.
 while (ss.available() > 0)
    if (gps.encode(ss.read()))
        displayInfo();
  if (millis() > 5000 && gps.charsProcessed() < 10)
    Serial.println(F("No GPS detected: check wiring."));
    while(true);
void displayInfo()
 // Serial.print(F("Location: "));
  if (gps.location.isValid())
    double latitude = (gps.location.lat());
    double longitude = (gps.location.lng());
    double speedy = (gps.speed.kmph());
    String latbuf;
    latbuf += (String(latitude, 6));
    Serial.println(latbuf);
    String lonbuf;
    lonbuf += (String(longitude, 6));
    Serial.println(lonbuf);
    String speedybuf;
    speedybuf += (String(speedy, 2));
    Serial.println(speedybuf);
    if(speedy>70){
    // update value
    Firebase.setFloat("Latitude", latitude);
    // handle error
    if (Firebase.failed()) {
        Serial.print("setting latitude failed:");
        Serial.println(Firebase.error());
        return;
    Firebase.setFloat("Longitude", longitude);
    // handle error
        Serial.print("setting longitude failed:");
        return;
    Firebase.setFloat("Speed", speedy);
    // handle error
        Serial.print("setting speed failed:");
        return;
    Serial.print(F("INVALID"));
[error]
Arduino: 1.8.10 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Multiple libraries were found for "SoftwareSerial.h"
In file included from C:\Users\Mariana\Documents\Arduino\libraries\firebase-arduino-master\src/FirebaseArduino.h:22:0,
Used: C:\Users\Mariana\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0\libraries\SoftwareSerial
Multiple libraries were found for "ESP8266WiFi.h"
from C:\Users\Mariana\Documents\Arduino\sketch_nov13a\sketch_nov13a.ino:4:
Used: C:\Users\Mariana\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0\libraries\ESP8266WiFi
C:\Users\Mariana\Documents\Arduino\libraries\firebase-arduino-master\src/Firebase.h:26:25: fatal error: ArduinoJson.h: No such file or directory
Multiple libraries were found for "FirebaseArduino.h"
#include <ArduinoJson.h>
Used: C:\Users\Mariana\Documents\Arduino\libraries\firebase-arduino-master
Multiple libraries were found for "TinyGPS++.h"
compilation terminated.
Used: C:\Users\Mariana\Documents\Arduino\libraries\TinyGPSPlus-master
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
option enabled in File -> Preferences.
[/error]
Multiple libraries are not an error, they are just information so you know which one the compiler used to compile your code.
The error is the missing ArduinoJason.h file which usually means you didn't install it, but need to.
I already add ArduinoJson libraries..
The error that appear is below:
[error]
GPS:23:31: error: no matching function for call to 'SoftwareSerial::SoftwareSerial(const int&, const int&)'
C:\Users\Mariana\Documents\Arduino\GPS\GPS.ino:23:31: note: candidate is:
In file included from C:\Users\Mariana\Documents\Arduino\GPS\GPS.ino:2:0:
C:\Users\Mariana\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0\libraries\SoftwareSerial\src/SoftwareSerial.h:49:5: note: SoftwareSerial::SoftwareSerial()
SoftwareSerial();
C:\Users\Mariana\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0\libraries\SoftwareSerial\src/SoftwareSerial.h:49:5: note: candidate expects 0 arguments, 2 provided
C:\Users\Mariana\Documents\Arduino\GPS\GPS.ino: In function 'void setup()':
GPS:30:19: error: no matching function for call to 'SoftwareSerial::begin(const uint32_t&)'
ss.begin(GPSBaud);
C:\Users\Mariana\Documents\Arduino\GPS\GPS.ino:30:19: note: candidate is:
C:\Users\Mariana\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0\libraries\SoftwareSerial\src/SoftwareSerial.h:53:10: note: void SoftwareSerial::begin(uint32_t, int8_t, int8_t, SoftwareSerialConfig, bool, int, int)
void begin(uint32_t baud, int8_t rxPin, int8_t txPin = -1,
C:\Users\Mariana\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0\libraries\SoftwareSerial\src/SoftwareSerial.h:53:10: note: candidate expects 7 arguments, 1 provided
Multiple libraries were found for "ESP8266HTTPClient.h"
Used: C:\Users\Mariana\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0\libraries\ESP8266HTTPClient
Multiple libraries were found for "ArduinoJson.h"
Used: C:\Users\Mariana\Documents\Arduino\libraries\ArduinoJson
exit status 1
[\error]
Look at the examples for SoftwareSerial for the ESP8266. You don't specify the Tx and Rx pins in the delcaration, but in the begin() function, along with the baud.
SoftwareSerial ss;
	ss.begin(GPSBaud, RxPin, TxPin);
