When using code examples from library items I repeatedly get the following error or a similar one indicating too many loop definitions. I'm a babe in the woods when it comes to coding and usually use examples to power my projects. I'm not creating anything I just like to see what is happening when you put things together.
main.cpp.o (symbol from plugin): In function atexit': (.text+0x0): multiple definition of loop'
C:\Users\nlkir\AppData\Local\Temp\arduino\sketches\1DEDCAB07D328BE4124A273397C3DF57\sketch\spfd5408_graphicstest.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
/code
// IMPORTANT: Adafruit_TFTLCD LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
// SEE RELEVANT COMMENTS IN Adafruit_TFTLCD.h FOR SETUP.
// Modified for SPFD5408 Library by Joao Lopes
// Version 0.9.2 - Rotation for Mega and screen initial
// *** SPFD5408 change -- Begin
#include <SPFD5408_Adafruit_GFX.h> // Core graphics library
#include <SPFD5408_Adafruit_TFTLCD.h> // Hardware-specific library
#include <SPFD5408_TouchScreen.h>
// *** SPFD5408 change -- End
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// When using the BREAKOUT BOARD only, use these 8 data lines to the LCD:
// For the Arduino Uno, Duemilanove, Diecimila, etc.:
// D0 connects to digital pin 8 (Notice these are
// D1 connects to digital pin 9 NOT in order!)
// D2 connects to digital pin 2
// D3 connects to digital pin 3
// D4 connects to digital pin 4
// D5 connects to digital pin 5
// D6 connects to digital pin 6
// D7 connects to digital pin 7
// For the Arduino Mega, use digital pins 22 through 29
// (on the 2-row header at the end of the board).
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
// -- Setup
void setup(void) {
progmemPrintln(PSTR("TFT LCD test"));
#ifdef USE_ADAFRUIT_SHIELD_PINOUT
progmemPrintln(PSTR("Using Adafruit 2.8" TFT Arduino Shield Pinout"));
#else
progmemPrintln(PSTR("Using Adafruit 2.8" TFT Breakout Board Pinout"));
#endif
tft.reset();
// Original code commented
// uint16_t identifier = tft.readID();
// if(identifier == 0x9325) {
// Serial.println(F("Found ILI9325 LCD driver"));
// } else if(identifier == 0x9328) {
// Serial.println(F("Found ILI9328 LCD driver"));
// } else if(identifier == 0x7575) {
// Serial.println(F("Found HX8347G LCD driver"));
// } else if(identifier == 0x9341) {
// Serial.println(F("Found ILI9341 LCD driver"));
// } else if(identifier == 0x8357) {
// Serial.println(F("Found HX8357D LCD driver"));
// } else {
// Serial.print(F("Unknown LCD driver chip: "));
// Serial.println(identifier, HEX);
// Serial.println(F("If using the Adafruit 2.8" TFT Arduino shield, the line:"));
// Serial.println(F(" #define USE_ADAFRUIT_SHIELD_PINOUT"));
// Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
// Serial.println(F("If using the breakout board, it should NOT be #defined!"));
// Serial.println(F("Also if using the breakout, double-check that all wiring"));
// Serial.println(F("matches the tutorial."));
// return;
// tft.begin(identifier);
// Code changed to works
tft.begin(0x9341); // SDFP5408
tft.setRotation(0); // Need for the Mega, please changed for your choice or rotation initial
progmemPrintln(PSTR("Benchmark Time (microseconds)"));
progmemPrint(PSTR("Screen fill "));
Serial.println(testFillScreen());
progmemPrint(PSTR("Text "));
Serial.println(testText());
delay(3000);
progmemPrint(PSTR("Lines "));
Serial.println(testLines(CYAN));
progmemPrint(PSTR("Horiz/Vert Lines "));
Serial.println(testFastLines(RED, BLUE));
progmemPrint(PSTR("Rectangles (outline) "));
Serial.println(testRects(GREEN));
progmemPrint(PSTR("Rectangles (filled) "));
Serial.println(testFilledRects(YELLOW, MAGENTA));
progmemPrint(PSTR("Circles (filled) "));
Serial.println(testFilledCircles(10, MAGENTA));
progmemPrint(PSTR("Circles (outline) "));
Serial.println(testCircles(10, WHITE));
progmemPrint(PSTR("Triangles (outline) "));
Serial.println(testTriangles());
progmemPrint(PSTR("Triangles (filled) "));
Serial.println(testFilledTriangles());
progmemPrint(PSTR("Rounded rects (outline) "));
Serial.println(testRoundRects());
progmemPrint(PSTR("Rounded rects (filled) "));
Serial.println(testFilledRoundRects());
progmemPrintln(PSTR("Done!"));
void loop(void) {
for(uint8_t rotation=0; rotation<4; rotation++) {
tft.setRotation(rotation);
testText();
delay(2000);
unsigned long testFillScreen() {
unsigned long start = micros();
tft.fillScreen(BLACK);
tft.fillScreen(RED);
tft.fillScreen(GREEN);
tft.fillScreen(BLUE);
return micros() - start;
unsigned long testText() {
tft.setCursor(0, 0);
tft.setTextColor(WHITE); tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(YELLOW); tft.setTextSize(2);
tft.println(1234.56);
tft.setTextColor(RED); tft.setTextSize(3);
tft.println(0xDEADBEEF, HEX);
tft.println();
tft.setTextColor(GREEN);
tft.setTextSize(5);
tft.println("Groop");
tft.setTextSize(2);
tft.println("I implore thee,");
tft.setTextSize(1);
tft.println("my foonting turlingdromes.");
tft.println("And hooptiously drangle me");
tft.println("with crinkly bindlewurdles,");
tft.println("Or I will rend thee");
tft.println("in the gobberwarts");
tft.println("with my blurglecruncheon,");
tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
unsigned long start, t;
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
x2 = w - 1;
for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
t = micros() - start; // fillScreen doesn't count against timing
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
t += micros() - start;
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
unsigned long start;
int x, y, w = tft.width(), h = tft.height();
start = micros();
for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
int n, i, i2,
cx = tft.width() / 2,
cy = tft.height() / 2;
n = min(tft.width(), tft.height());
start = micros();
for(i=2; i<n; i+=6) {
i2 = i / 2;
tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
unsigned long start, t = 0;
int n, i, i2,
cx = tft.width() / 2 - 1,
cy = tft.height() / 2 - 1;
for(i=n; i>0; i-=6) {
i2 = i / 2;
start = micros();
tft.fillRect(cx-i2, cy-i2, i, i, color1);
// Outlines are not included in timing results
tft.drawRect(cx-i2, cy-i2, i, i, color2);
return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
start = micros();
for(x=radius; x<w; x+=r2) {
for(y=radius; y<h; y+=r2) {
tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
int x, y, r2 = radius * 2,
w = tft.width() + radius,
h = tft.height() + radius;
// Screen is not cleared for this one -- this is
// intentional and does not affect the reported time.
start = micros();
for(x=0; x<w; x+=r2) {
for(y=0; y<h; y+=r2) {
tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
int n, i, cx = tft.width() / 2 - 1,
n = min(cx, cy);
start = micros();
for(i=0; i<n; i+=5) {
tft.drawTriangle(
cx , cy - i, // peak
cx - i, cy + i, // bottom left
cx + i, cy + i, // bottom right
tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
int i, cx = tft.width() / 2 - 1,
start = micros();
for(i=min(cx,cy); i>10; i-=5) {
start = micros();
tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(0, i, i));
tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(i, i, 0));
return t;
unsigned long testRoundRects() {
int w, i, i2,
w = min(tft.width(), tft.height());
start = micros();
for(i=0; i<w; i+=6) {
i2 = i / 2;
tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
int i, i2,
start = micros();
for(i=min(tft.width(), tft.height()); i>20; i-=6) {
i2 = i / 2;
tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
// Copy string from flash to serial port
// Source string MUST be inside a PSTR() declaration!
void progmemPrint(const char *str) {
char c;
while(c = pgm_read_byte(str++)) Serial.print(c);
// Same as above, with trailing newline
void progmemPrintln(const char *str) {
progmemPrint(str);
/code
