Just a simple question ...
Code 1:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
else {
// turn LED off:
digitalWrite(ledPin, LOW);
Code 2: #include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
How can you put these 2 codes together?
(With the condition that the servo turns on, when the switch is turned on.)
It sounds very easy. Put all the setup under void setup and put all the loop under void loop.
But we can't get it done. We're getting errors all the time.
Can't sit idle by if one of my fellow dutchies is in trouble!
kalemeister:
Post the code where you put everything together. Probably a bracket problem...
const int ledPin = 9; // the number of the LED pin
#include <Servo.h>
void loop(){
// turn LED on:
else {
// turn LED off:
This is what I got. This time I got no errors. But the servo doesn't do anything...
Okay sorry. We are just beginners.
Here's the code:
const int servoPin = 9;
#include <Servo.h>
pinMode(servoPin, OUTPUT);
void loop(){
// turn LED on:
else {
// turn LED off:
kalemeister:
What do you mean by debug serial print ?
It means a serial output to check is your program is running.
#include <SoftwareSerial.h> //To include the serial code
#include <Servo.h>
Serial.begin(9600); //start serial communication at 9600baud
void loop(){
Serial.println("Knop is ingedrukt"); //print to the serial monitor
// turn LED on:
else {
// turn LED off:
After uploading this, go to "Tools" and "Serial Monitor". Then select the baud rate of 9600 (Bottom right) and see if there is an output if you press the button.
kalemeister:
When we open the monitor, it says: "Knop is ingedrukt".
When we switch the lever, the monitor doesn't react to it.
Let me guess, the monitor keeps giving the output and stops when you press the button/lever?
How did you connect the button/leaver electrically? Is the LED on all the time until you press the button/lever?
Put some more serial prints in, to help you see where the logic takes you.
// turn LED on:
Serial.println("servo increment"); //print to the serial monitor <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Serial.println("servo decrement"); //print to the serial monitor <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
else {
// turn LED off:
Serial.println("button not pushed"); //print to the serial monitor <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
kalemeister:
Yeah, it says: 'Knop is ingedrukt' (just 1 time). And nothing else. Also not when we switch the lever.
kalemeister:
Again: How did you connect the button electrical? Can you draw the schematic and upload it or something...?
I reversed the logic: changed the button from INPUT to INPUT_PULLUP, and look for a LOW on the button not a HIGH. (edit.... I did that since I suspect you have no pulldown resistor, but instead of me wiring one in, it's easier to go internal pullup. That reverses the logic though...)
if (buttonState == LOW) {
****************CHANGE THE BUTTON WIRING TO BE FROM PIN TO GROUND NOT 5V
#include <Servo.h>
pinMode(buttonPin, INPUT_PULLUP);
void loop(){
// turn LED on:
Serial.println("servo +"); //print to the serial monitor
Serial.println("servo -"); //print to the serial monitor
else {
// turn LED off:
Serial.println("not pushed"); //print to the serial monitor
You'll realise that once you press the button and the test for pressed is passed, the servo completes its journey even when you release the button.
