Hello, Can I program multiple Arduinos connected with Lora RA-02 sending to one Arduino connected with a Lora RA-02 that acts as aggregator?
Yes.
srnet:
Yes.
How? Because the example code of Lora library is only for one receiver and one transmitter every time...
alex5678:
Well, if you provide details of what you actually want to do, as in describing your project, you might get some suggestions.
I have 2 Arduino pro minis connected with temperature sensors and Lora RA-02 and I want these measurements to send them on an aggregator which also use RA-02...
When you send the sensor data, have the first byte, of the buffer\payload represent the sensor number.
What exactly does the 'aggregator' it do with the data it receives ?
It is connected to the laptop through the Serial to get the measurements.
