I'm in the process of building a multiple burner melting furnace, using servos to control the fuel feed based on furnace temperatures
I have everything working except getting usable readings out of the tcouples using max6675 and a Mega2560
below is the relevant code
//sketch tilting furnace
#include "Servo.h"
#include "max6675.h"
// Declare the max6675 thermocouple
//CRUCIBLE max6675
int tcSO = 8; // 6675 Serial Output Crucible
int tcCS = 9; // 6675 Chip Select Crucible
int tcCLK = 10; // 6675 Clock Crucible
float DegreesF_cf = 0; // CRUCIBLE TEMP
float cfSETP; // CRUCIBLE SETPOINT
MAX6675 tc(tcCLK, tcCS, tcSO );
// TILT max6675
int tcFSO = 28; // 6675 Serial Output Tilting
int tcFCS = 29; // 6675 Chip Select Tilting
int tcFCLK = 30; // 6675 Tilting Clock Pin Tilting
float DegreesF_tf = 0; // TILT TEMP
float tfSETP; // TILT SETPOINT
MAX6675 tcF(tcFCLK, tcFCS, tcFSO );
DegreesF_tf = tcF.readFahrenheit();
delay(100);
DegreesF_cf = tc.readFahrenheit();
delay(100);
This is a typical application of the sensors
{ // Crucible burner control
if (digitalRead(CPBS) == LOW) {
digitalWrite(CPV, LOW);
} // pilot switch activates pilot
cfSETP = 1500; [b]DegreesF_cf = tc.readFahrenheit();[/b]
{ if (digitalRead(COBS) == LOW) //oil switch enables oil burner opeation based on tcouple
{ if (cfSETP - DegreesF_cf > 100)COservo.write(40);// crucible oil control
else {
{ if (cfSETP - DegreesF_cf < 100)COservo.write(((cfSETP - DegreesF_cf) / 4) + 10);
else {
if (cfSETP - DegreesF_cf <= 0)COservo.write (10);
the "servo" goes to 4o
the "degreesF_cf" goes to 32
Do the Max6675s need to be "ATTACHED" as the servos did or does declaring "INT" accomplish that????
Do the pins need to be set as "INPUT" etc.
thanks in advance
Art B
