Multiple Max7219s and LedControl Library
The problem that I am having with the LedControl library is a peculiar one. I'm using an Arduino Uno, three Max7219's daisy-chained together controlling three 8x8 LED grids, and I am using the LedControl library. Everything works and runs fine. I've got no problems except this:
When I first plug in my LED matrix, my Arduino Uno receives power via the 5V line and my whole system turns on together. When everything first turns on, the number of MaxDevices is set to 3. All the LEDs turn on and function properly except only the LEDs on the first Max are at the proper brightness. The LEDs on the 2nd and 3rd Max's are significantly dimmer.
Now, if I change MaxDevices to 1 and re-flash the Uno with the same program except MaxDevice is set to 1, all the LEDs are restored to full brightness, but the program doesn't work properly because it thinks there is only 1 Max. So, I change the number of MaxDevices to 3, reflash the program, and now everything works as intended and all the LEDs are full brightness. I don't understand what the problem could be.
Here is my code.
#include "LedControl.h"
//Thanks to Eberhard Fahle
  // LedControl Pins
  int MAX_DATA_IN   = 12;       // RED
  int MAX_CLOCK     = 11;       // BLUE
  int MAX_LOAD      = 10;       // GREEN
  int MaxDevice     = 3;       // 1, 2, 3
  LedControl MaxMatrix (MAX_DATA_IN, MAX_CLOCK, MAX_LOAD, MaxDevice);    // Initialize Led Controller library called MaxMatrix
int timer = 200;
void setup(){
//  1.  Set MAX Devices
        for(byte i=0;i<MaxMatrix.getDeviceCount();i++){
              MaxMatrix.shutdown(i, false);    // Bring the Max out of Shutdown Mode and into Normal Operation Mode
              MaxMatrix.setIntensity(0, 10);
              MaxMatrix.clearDisplay(i);       // Clear the display
        MaxTest();
}  //---------------------------------------------------- END SETUP
void loop(){
void MaxTest(){
  for (int i = 0; i < 3; i++){
     for (int t = 0; t < 8; t++){
        MaxMatrix.setColumn(i, t, 128);
        delay(timer);
        MaxMatrix.setColumn(i, t, 192);
        delay(timer);
        MaxMatrix.setColumn(i, t, 224);
        delay(timer);
        MaxMatrix.setColumn(i, t, 240);
        delay(timer);
        MaxMatrix.setColumn(i, t, 248);
        delay(timer);
        MaxMatrix.setColumn(i, t, 252);
        delay(timer);
        MaxMatrix.setColumn(i, t, 254);
        delay(timer);
        MaxMatrix.setColumn(i, t, 255);
        delay(timer);
        MaxMatrix.setColumn(i,t,0);
        MaxMatrix.setRow(i, t, 128);
        delay(timer);
        MaxMatrix.setRow(i, t, 192);
        delay(timer);
        MaxMatrix.setRow(i, t, 224);
        delay(timer);
        MaxMatrix.setRow(i, t, 240);
        delay(timer);
        MaxMatrix.setRow(i, t, 248);
        delay(timer);
        MaxMatrix.setRow(i, t, 252);
        delay(timer);
        MaxMatrix.setRow(i, t, 254);
        delay(timer);
        MaxMatrix.setRow(i, t, 255);
        delay(timer);
        MaxMatrix.setRow(i, t, 0);
}}}//----------------------------------------------------- END MaxTest
So the process basically goes:
  1. Turn on system and begin running sketch. (Max Device is set to 3 from previous use)
  • LEDs on 2nd and 3rd Max's are dim
  1. Reflash Arduino with MaxDevices set to 1
  • All LEDs at correct brightness but sketch does not work correctly
  1. Reflash Arduino with MaxDevices set to 3
  • All LEDs at correct brightness and sketch works correctly
I'm reluctant to post a schematic because I've spent more time trying to figure out how to draw a Max7219 in Fritzing to show the layout on the breadboard (with no success) than I have actually trying to solve the problem. So here are some pictures.
Imgur
Imgur
Imgur
I have a 5V DC, 6 Amp regulated power supply and I've had all LEDs set to on at the same time no problem so I don't think it is a power supply issue.
I have caps on each chip for noise.
Just the fact that I flash the Arduino and change nothing but the number of Max Devices from 3 to 1 to 3 solves it, makes me think it has something to do with the LedControl library but I don't know.
I'm truly at a loss for this issue and it is driving me crazy.
I'm happy to report that I solved my problem. Within setup and my call to bring the Max out of Shutdown more and set the intensity was called through a for loop. And, my call to set the intensity was set to the fixed value of 0 (for the first Max device) instead of to the variable "i" so only the first Max device was getting the call to to set the intensity while the intensity of the 2nd and 3rd Max's never got updated until I changed the Max Device to 1. Then the intensity of all the Max devices would get set because the call to 1 max device would get copied to all Max devices.
Oh boy! Just goes to show what a good night sleep and a good read of the datasheet can do! :slight_smile:
