Multiple MMA7361 (accelerometer) in a project?
I trying to make some angle calculation (well at least get a tilt to give me a hight) and I get readings from one 7361, and from that I think I can get what I need.
But I need to get one more sensor to give me one more reading on the next part, I was hooking it up and realised that I didnt know where to put wires :blush:
How do I connect sensor 2 and get readings?
This is simple code for start, have no use for reading from just 1 sensor so no need to “waste” time making calculations and fancy code, but that might be a later problem :cold_sweat:
This give me values when I tilt sensor 1, and I think it will be a start.
#include <AcceleroMMA7361.h>
AcceleroMMA7361 accelero;
int x;
int y;
int z;
 accelero.begin(13, 12, 11, 10, A0, A1, A2);
 accelero.setARefVoltage(5); //sets the AREF voltage to 3.3V
 accelero.setSensitivity(HIGH); //sets the sensitivity to +/-6G
// accelero.calibrate();
// x = accelero.getXAccel();
 y = accelero.getYAccel();
// z = accelero.getZAccel();
// Serial.print("\nx: ");
// Serial.print(x);
 Serial.print(" \ty: ");
 Serial.print(y);
 delay(1000); //make it readable
Here is a sketch of what i plan, the round parts is joints.
If this works fine I might add a 3:rd sensor also…
hello, do you have a sketch about accelerometer mma7361+arduino to move a motor dc?
thanks
