Multiple MPU 6050 (continue)
i had previously open a post :
http://forum.arduino.cc/index.php?topic=259533.0
regarding connecting multiple MPU6050.
I need to connect 4 MPU6050 in one arduino uno board. So there are few people provided me few suggestions in the previous post.
According to thier method, I can use a multiplexer (74HC4051N in my case) and select the AD0 pin to address low (0x68) once at a time. So i followed the instruction and the attached diagram is the connection.
I am storing the result into a micro sd card by using the micro sd card shield from sparkfun. I did manage to get results and store in the micro sd card for 4 imu, however I noticed there are many readings are 0 when at rest (which means the raw reading sometime roughly 16384 and sometime 0 when parallel to gravity). And when I tried to only stored the result from 1 imu into micro sd card without using multiplexer, the results is normal (which means the raw reading is roughly 16384 when parallel to gravity) .
So now I am wondering is there anything wrong with the connection or code?
Please help.
The code I am using is as follow:
#include "Wire.h"
#include "I2Cdev.h"
#include "MPU6050.h"
#include <SPI.h>
#include <SD.h>
#define FILE_BASE_NAME "Waist"
const uint8_t CS_PIN = 8;
File file;
const uint8_t BASE_NAME_SIZE = sizeof(FILE_BASE_NAME) - 1;
char fileName[] = FILE_BASE_NAME "00.csv";
MPU6050 accelgyro ;
int16_t  ax, ay, az, gx, gy, gz, ax1, ay1, az1, gx1, gy1, gz1,ax2, ay2, az2, gx2, gy2, gz2, ax3, ay3, az3, gx3, gy3, gz3;
//ASSIGN DIGITAL PINS (MUX)
int S0 = 5;
int S1 = 6;
int S2 = 7;
unsigned long time;
//MANUALLY CONTROL THE LINE OF MULTIPLEXER TO SELECT THE PIN CONNECTED TO AD0
void out1()
  digitalWrite(S0, LOW);
  digitalWrite(S1, LOW);
  digitalWrite(S2, LOW);
void out2()
  digitalWrite(S0, HIGH);
void out3()
  digitalWrite(S1, HIGH);
void out4()
  #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
        Wire.begin();
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
  Serial.begin(38400);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
    pinMode(CS_PIN, OUTPUT);
    while(!SD.begin(CS_PIN)) {
  while (SD.exists(fileName)) {
    if (fileName[BASE_NAME_SIZE + 1] != '9') {
      fileName[BASE_NAME_SIZE + 1]++;
    } else if (fileName[BASE_NAME_SIZE] != '9') {
      fileName[BASE_NAME_SIZE + 1] = '0';
      fileName[BASE_NAME_SIZE]++;
      Serial.println(F("Can't create file name"));
      return;
  accelgyro.initialize();
   File file = SD.open(fileName, FILE_WRITE);
  if (file) {
time=millis();
    out1();
    accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    out2();
    accelgyro.getMotion6(&ax1, &ay1, &az1, &gx1, &gy1, &gz1);
    out3();
    accelgyro.getMotion6(&ax2, &ay2, &az2, &gx2, &gy2, &gz2);
    out4();
    accelgyro.getMotion6(&ax3, &ay3, &az3, &gx3, &gy3, &gz3);
    file.print(time);
    file.print(",");
    file.print(ax);
    file.print(",");
    file.print(ay);
    file.print(",");
    file.print(az);
    file.print(",");
    file.print(gx);
    file.print(",");
    file.print(gy);
    file.print(",");
    file.print(gz);
    file.print(",");
    file.print(ax1);
    file.print(",");
    file.print(ay1);
    file.print(",");
    file.print(az1);
    file.print(",");
    file.print(gx1);
    file.print(",");
    file.print(gy1);
    file.print(",");
    file.print(gz1);
    file.print(",");
    file.print(ax2);
    file.print(",");
    file.print(ay2);
    file.print(",");
    file.print(az2);
    file.print(",");
    file.print(gx2);
    file.print(",");
    file.print(gy2);
    file.print(",");
    file.print(gz2);
    file.print(",");
    file.print(ax3);
    file.print(",");
    file.print(ay3);
    file.print(",");
    file.print(az3);
    file.print(",");
    file.print(gx3);
    file.print(",");
    file.print(gy3);
    file.print(",");
    file.print(gz3);
    Serial.print(time);
    Serial.print(",");
    Serial.print(ax);
    Serial.print(",");
    Serial.print(ay);
    Serial.print(",");
    Serial.print(az);
    Serial.print(",");
    Serial.print(gx);
    Serial.print(",");
    Serial.print(gy);
    Serial.print(",");
    Serial.print(gz);
    Serial.print(",");
    Serial.print(ax1);
    Serial.print(",");
    Serial.print(ay1);
    Serial.print(",");
    Serial.print(az1);
    Serial.print(",");
    Serial.print(gx1);
    Serial.print(",");
    Serial.print(gy1);
    Serial.print(",");
    Serial.println(gz1);
    Serial.print(",");
    Serial.print(ax2);
    Serial.print(",");
    Serial.print(ay2);
    Serial.print(",");
    Serial.print(az2);
    Serial.print(",");
    Serial.print(gx2);
    Serial.print(",");
    Serial.print(gy2);
    Serial.print(",");
    Serial.print(gz2);
    Serial.print(",");
    Serial.print(ax3);
    Serial.print(",");
    Serial.print(ay3);
    Serial.print(",");
    Serial.print(az3);
    Serial.print(",");
    Serial.print(gx3);
    Serial.print(",");
    Serial.print(gy3);
    Serial.print(",");
    Serial.println(gz3);
  file.println();
    file.close();
    Serial.println("error opening datalog.txt");
     delay(10);
Hi
Your MPUs have address of 68 or 69?
I'm missing definite voltage levels on the A0 lines. The 4051 connects only one line to Vee, the other pins are disconnected (floating)! I'd use pullup/down resistors to keep the unselected pins at a defined level (0 or 3.3V).
As long as you want to connect only 4 modules, you can use 4 digital output pins to drive the 4 A0 lines. In this case a voltage divider on each pin (e.g. DigOut--2k2--A0--3k3--Gnd) should limit the A0 output voltage to 3.3V. Also 22k/33k may work, consuming less power.
Hi!
I am using your topic as a reference for my project but I am in doubt about how to continue.
I've got the MPU6050 IMUs and your Mux. When I connect them to my arduino Board looks like that the arduino is reading values in a wrog way because, it doesn't matter which IMU I move, all the values change.
Could you help me?
thanks
