Multiple networkclients
I'm a beginner with Arduino. I own a Arduino Uno with a network shield.
After some tutorials i'm able to control a few leds and read the temperature from a sensor via the web.
But I want to upload the sensor data too with a interval. I have tried some tutorial's but no one works with a webpage and a uploadfunction.
My question is: Is it possible to do both actions? If yes, how?
This is the code I have now. (It tries the first time to upload and after that i must restart the Arduino to make it available again.
  Web Server
A simple web server
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
#include <SPI.h>
#include <Ethernet.h>
#include <SdFat.h>
//Temperatuur en luchtvochtigdheid
#include <dht.h>
#include <math.h>
#define dht_dpin A0 //no ; here. Set equal to channel sensor is on
dht DHT;
String writeAPIKey = "XXXXXXXX";
String channelID = "67827";
EthernetClient client2;
float x;
float y;
SdFat SD;
SdFile myFile;
char buffer;
// Enter a MAC address and IP address for your controller below.
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0x48, 0xD3 };
// The IP address will be dependent on your local network:
// assign an IP address for the controller:
IPAddress ip(192,168,178,177);
IPAddress gateway(192,168,178,1);
IPAddress subnet(255, 255, 255, 0);
// Initialize the Ethernet server library with the port you want to use.
EthernetServer server(80);
EthernetClient client;
String readString;
// Any extra codes for Declaration :
// Declare Pin 8 as an LED because thats what we will be connecting the LED to.You could use any other pin and would then have to change the pin number.
int led = 8;
int led2 = 9;
int led3 = 7;
int led4 = 6;
  pinMode(led, OUTPUT); //pin selected to control
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(10, OUTPUT);            // ethernet shield uitschakelen
  digitalWrite(10, HIGH);         // zodat SPI bus vrijkomt
  SD.begin(4, SPI_FULL_SPEED);    // om sd-kaart te initialiseren
  //delay(300); // even opstarten
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  Serial.print("Server is at ");
  Serial.println(Ethernet.localIP());
  Serial.println("Niek's Domotica 1.0");
  // listen for incoming clients
  client = server.available();
  if (client)
    while (client.connected()){
      if (client.available()){
        char c = client.read();
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
       //   Serial.println(readString); //print to serial monitor for debuging
          client.println("Content-Type: text/html");
          client.println();
          myFile.open("page.htm", O_READ);
          Read_File_Upto_FS();
          if(digitalRead(led)){
            //oranje
            client.print("aan");
            client.print("uit");
          }else{
          if(digitalRead(led2)){
            //blauw
          }else{
          if(digitalRead(led3)){
            //rood
          }else{
          if(digitalRead(led4)){
            //Groen
          }else{
          DHT.read11(dht_dpin);
          client.print(DHT.temperature);
          client.print(DHT.humidity);
          Read_File_Upto_End();
          myFile.close();
          delay(1);
         //some code to switch the leds here
          readString = "";
          client.stop();
  ThingSpeakUpdate("?key=XXXXXXXXXXXXX&temp=" + String(DHT.temperature) + "&hum="+ String(DHT.humidity));
Sends sensor data to Thingspeak
Inputs: String, data to be entered for each field
Returns:
void ThingSpeakUpdate(String tsData)
    Serial.println("Date string: " + tsData);
    Serial.println("...Connecting to Thingspeak");
    // Connecting and sending data to Thingspeak
    if(client2.connect("https://api.thingspeak.com", 80))
        Serial.println("...Connection succesful, updating datastreams");
        client2.print("GET /update/" + tsData + "HTTP/1.1\n");
        client2.print("Host: https://api.thingspeak.com/update\n");
        client2.print("Connection: close\n");
        //client2.print("X-THINGSPEAKAPIKEY: "+writeAPIKey+"\n");
        client2.print("Content-Type: application/x-www-form-urlencoded\n");
        client2.print("Content-Length: ");
        client2.print(tsData.length());
        client2.print("\n\n");
        //client2.println(tsData); //the ""ln" is important here.
        // This delay is pivitol without it the TCP client will often close before the data is fully sent
        Serial.println("Thingspeak update sent.");
    else{
        // Failed to connect to Thingspeak
        Serial.println("Unable to connect to Thingspeak.");
    if(!client2.connected()){
        client2.stop();
    client2.flush();
    client2.stop();
void Read_File_Upto_FS() {
  while ((buffer = myFile.read()) != 28) {
    client.print((char)buffer);
void Read_File_Upto_End() {
  while ((buffer = myFile.read()) >= 0) {
void Skip_File_Upto_FS() {
    // nothing
A Host name does NOT include a protocol. Get rid of the https:// bit. A host name does NOT include a path. Lose the /update bit.
See that comment? It means what it says. The last line send to the client MUST be sent using println().
Instead of just dumping the server response, a clue by four just might whack you if you read and printed the response.
Yes, use combined client/server code. Note that the arduino does not support secure https connections.
