i try to create a uno with multiple reader, RC522
with the multireader example
only problem is how to compare my tag number that is correct with the scanned tag.
my code is, and my question is what should be in place of xxxx
* Example sketch/program showing how to read data from more than one PICC to serial.
* This is a MFRC522 library example; for further details and other examples see: https://github.com/miguelbalboa/rfid
* Example sketch/program showing how to read data from more than one PICC (that is: a RFID Tag or Card) using a
* MFRC522 based RFID Reader on the Arduino SPI interface.
* Warning: This may not work! Multiple devices at one SPI are difficult and cause many trouble!! Engineering skill
* and knowledge are required!
* @license Released into the public domain.
* Typical pin layout used:
* MFRC522 Arduino Arduino Arduino Arduino Arduino
* Reader/PCD Uno/101 Mega Nano v3 Leonardo/Micro Pro Micro
* Signal Pin Pin Pin Pin Pin Pin
* RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
* SPI SS 1 SDA(SS) ** custom, take a unused pin, only HIGH/LOW required **
* SPI SS 2 SDA(SS) ** custom, take a unused pin, only HIGH/LOW required **
* SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
* SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
* SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_1_PIN 10 // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 2
#define SS_2_PIN 8 // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
#define SS_3_PIN 6 // Configurable, take a unused pin, only HIGH/LOW required, must be diffrent to SS 1
#define NR_OF_READERS 3
byte ssPins[] = {SS_1_PIN, SS_2_PIN, SS_3_PIN};
MFRC522 mfrc522[NR_OF_READERS]; // Create MFRC522 instance.
* Initialize.
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
Serial.print(F("Reader "));
Serial.print(reader);
Serial.print(F(": "));
mfrc522[reader].PCD_DumpVersionToSerial();
* Main loop.
// Look for new cards
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(": Card UID:"));
dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
char *validData = "B0 8B 24 83";
if(strcmp(validData, xxxx ) == 0 && reader == 1)
// Hey, the tag is valid
Serial.println("action!");
}else
Serial.println ("burn");
// Halt PICC
mfrc522[reader].PICC_HaltA();
// Stop encryption on PCD
mfrc522[reader].PCD_StopCrypto1();
} //if (mfrc522[reader].PICC_IsNewC
} //for(uint8_t reader
* Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
in this line : if(strcmp(validData, xxxx ) == 0 && reader == 1)
thanks
