hi guys.. as you can see in the subject is that I'm having a trouble using a single output LED to run using 2 different loops.. i'm trying to have a HIGH output on an LED1 once the comparison of my circuit1(real time clock - saves a running time in military setup) and the clock on my laptop.
here is the part of the code which should light up LED1 once the time is equal from the RTC to the time on my laptop.
if(((now.hour()==HOUR1)&&(now.minute()==MINUTE1)))
if(flag == 1)
lcd.setCursor(9,1);
lcd.print(" Med 1 ");
lcd.println();
digitalWrite(LED,HIGH);
delay(10000); //delay for 25sec
lcd.clear(); //Delete the Display of Medicine after the buzzer
delay(1000); //Delay time for the lcd.clear function
flag = 0; // clear flag
else {
digitalWrite(LED,LOW);
and here is the part of the code which I use to light up again the same LED when the arduino compares the time in the RTC and in my laptop
if(((now.hour()==HOUR4)&&(now.minute()==MINUTE4)))
if(flag4 == 1)
lcd.setCursor(9,1);
lcd.println();
digitalWrite(LED2,HIGH);
delay(5000); //delay for 1sec
flag4 = 0; // clear flag
else {
The first part of the comparing code is working and shows the result I want which lights up the LED1 for 10 seconds and then turns it off after. but on the 2nd part of the code when the time comparing is equal. i cannot light up the SAME LED1. do you know guys why is it like that? here is the copy of the whole code:
#include <Wire.h>
#include "RTClib.h"
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// Create RTC object
RTC_DS1307 RTC;
// Assign LED to digital pin 13
const int LED = 8;
const int LED2 = 9;
const int LED3 = 10;
// Flag for entering LED routines
uint8_t flag = 1;
uint8_t flag2 = 1;
uint8_t flag3 = 1;
uint8_t flag4 = 1;
uint8_t flagbuzz = 1; //flag comparison for Buzzer
// Set alarm to activate two times a day
byte HOUR1 = 19, MINUTE1 = 54;
byte HOUR2 = 19, MINUTE2 = 55;
byte HOUR3 = 19, MINUTE3 = 56;
byte HOUR4 = 19, MINUTE4 = 57;
void setup ()
pinMode(LED,OUTPUT); // LED pin as output
digitalWrite(LED,LOW); // Turn off LED by default
pinMode(LED2,OUTPUT); // LED pin as output
digitalWrite(LED2,LOW); // Turn off LED by default
pinMode(LED3,OUTPUT); // LED pin as output
digitalWrite(LED3,LOW); // Turn off LED by default
Serial.begin(57600); // Initialize serial & set baudrate
Wire.begin(); // Initialize I2C 2 wires interface
RTC.begin(); // Initialize DS1307 RTC chip
lcd.begin(16, 2); // Initialize LCD Interface
if (! RTC.isrunning()) // If RTC is not running, set the time
lcd.print("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(DATE, TIME));
void loop ()
// Read current time from RTC chip
DateTime now = RTC.now();
// Send current time to serial for debugging
// Using the lcd.print(); it display the former Serail.print to the LiquidCrystal lcd.setCursor(3,0);
// Date Display code
lcd.setCursor(3,0);
lcd.print(now.year(),DEC);
lcd.print('/');
lcd.print(now.month(),DEC);
lcd.print('/');
lcd.print(now.day(),DEC);
lcd.print(' ');
// Time Display code
lcd.setCursor(0,1);
lcd.print(now.hour(),DEC);
lcd.print(':');
lcd.print(now.minute(),DEC);
lcd.print(':');
lcd.print(now.second(),DEC);
lcd.println();
lcd.setCursor(8,1);
lcd.print(" ");
//Start of codes for alarm and Medicine number number display
// led red
if(flag == 1)
lcd.setCursor(9,1);
lcd.println();
else {
// led yellow
if(((now.hour()==HOUR2)&&(now.minute()==MINUTE2)))
if(flag2 == 1)
lcd.setCursor(9,1);
lcd.print(" Med 2 ");
lcd.println();
flag2 = 0; // clear flag
if(((now.hour()==HOUR3)&&(now.minute()==MINUTE3)))
if(flag3 == 1)
lcd.setCursor(9,1);
lcd.print(" Med 3 ");
lcd.println();
digitalWrite(LED3,HIGH);
flag3 = 0; // clear flag
if(flag4 == 1)
lcd.setCursor(9,1);
lcd.println();
else {
} //Final Closing Bracket for Void loop
