Has anyone had any luck with running multiple PCA9635's? I've got one running just fine using RAMBO's code here: GitHub - rambo/pca9635: Arduino library for controlling PCA9635 I2C LED drivers
The issue is that I can't find a way to address a second unit. I mean I CAN but if I define a second unit right below the initial definition as shown below (driver.begin(97, false) the code for 96 stops working. I assume that has to do with the standard format of the Wire library being to:
Wire.beginTransmission(44); // transmit to device #44
 Wire.write(byte(0x00)); // sends instruction byte
 Wire.write(val);    // sends potentiometer value byte
 Wire.endTransmission(); // stop transmitting
// Get this from https://github.com/rambo/I2C
#include <I2C.h> // For some weird reason including this in the relevant .h file does not work
#include <i2c_device.h> // For some weird reason including this in the relevant .h file does not work
#include <pca9635.h>
#define I2C_DEVICE_DEBUG
// Container for the device
pca9635 driver;
  // Use the SW-Reset address to reset all pca9635 ICs on the bus
  // Initialize I2C library manually
  I2c.begin();
  I2c.timeOut(500);
  PCA9635.reset(); // Incidentally this global name is a pca9635 instance bound to the generla "all-call" address so it can be used to set global parameters
  // Wake oscillators on all-call
  PCA9635.set_sleep(0x0);
  delayMicroseconds(500);
  // Enable PWM controls for all leds on all-call
  PCA9635.set_led_mode(3);
  * This will set the driver to open-drain mode, 0xff will set it to the default totem-pole mode
  PCA9635.set_driver_mode(0x0);
  // Set device address and call I2c.begin() (note: your need to change the address to correspond to your device)
  driver.begin(96, false); // ******** You need to change the device address here, 0x70 is the 7-bit ALL-CALL address for PCA9635 ***********
  driver.begin(97, false); // ******** You need to change the device address here, 0x70 is the 7-bit ALL-CALL address for PCA9635 ***********
  Serial.println(F("Booted"));
  // Scan the bus, output addresses (just
  I2c.scan();
 Â
  // Blink leds in turn on all-call
  Serial.println(F("Blinking all drivers leds' in turn (via ALL-CALL)"));
  for (byte ledno = 0; ledno < 16; ledno++)
    // Using half-brightness to make the led light up regardless of whether the drver is wired to source or sink current through it (when in totem-pole mode, open drain naturally is sink-only)
    PCA9635.set_led_pwm(ledno, 0x80);
    delay(250);
    PCA9635.set_led_pwm(ledno, 0x0);
  Serial.println(F("Blinking addressed drivers leds' in turn"));
  // Blink leds in turn on the addressed instance
    driver.set_led_pwm(ledno, 0x80);
    delay(250);
    driver.set_led_pwm(ledno, 0x0);
  // Dump device registers
  driver.dump_registers(0x0, 0x1b);
  delay(5000);
Any ideas on how to talk to a second PCA9635? It would seem that I need the ability to send an additional variable to the set_led_pwm function; namely an address variable.
