Multiple Port Manipulation
Hi All
I need to be able to change 10 outputs at exactly the same time; I'm aware of port manipulation but this only work for 8 I/O pins could I use something like the && statement?
  (PORTB = B11111111 &&  PORTD = B11111111);
  (PORTB = B00000000 &&  PORTD = B00000000);
Any advice would be helpful.
Thanks in advance
Dan
danb121:
Hi All
No, the && operator doesn't do that, you need to do this:
PORTB = B11111111;
PORTD = B11111111;
The timing difference will be one clock cycle. Normal Arduino clock speed is 16mHz.
If that's too much difference you'll have to add an external 16-bit shift register.
For anyone to be really helpful you need to put a number on how close to 'exactly' you mean. What is the maximum skew rate between output pins that you can live with, 1 millisec, 1 usec, 1 nanosec ? A lot of time beginners have not yet gained a feel for how fast a arduino clock cycle is in the real world.
If you cannot put a metric to 'exactly' then perhaps if you could describe what the output pins are going to be wired to and the function they will be performing.
Lefty
Doesn't matter what you do there's no way to change 10 pins at exactly the same time using the processor IO unless you move to a 16- or 32-bit chip.
Use fungus's solution.
Do you really need exactly? Why?
Rob
Cheers for the replies.
I'm using the arduino and circuit for highspeed photography, the flash guns have to have a low light output to minimise motion blur so to get the correct exposure I need to use multiple flash guns...
In answer to your question ideally the outputs would be changed at exactly the same time as firing flash guns at different times will also cause motion blur. My aim is to build a box that I can use for a number of different situations and enviroments; having said that the extra 2 outputs are just for contingency so I could live without them
I'll also do some tests to see if firing 2 outputs with a slight delay will cause a problem :slight_smile:
Thanks again
Dan
danb121:
OK, but that doesn't answer the maximum timing skew between output changes allowed. There has to be a value which is fast enough to not cause detection, and it might be that even some microseconds is fast enough.
Now that is something constructive to try. delayMicroseconds() is available for that testing effort, I believe that command has a 4 microsecond resolution.
Lefty
Thanks again
Dan
