Multiple Potentiometers Should be in Parallel?
While measuring my circuit with two potentiometers sharing a ground and 5v and the wipers in to the analog inputs, I realized this circuit is in parallel and my 10ks are now really 5k.
Is there a better way to wire this circuit? Should I be buying higher resistance potentiometers when using multiples?
Each 10k pot will draw 0.5 mA. I don't think there is need to go to higher resistance. Connect each wiper to a different analog input pin and they should all work just fine.
