Multiple RFID readers.
Ok, I saw that a lot of people has my problem but haven't find a solution yet.
I try to build Black Jack by mega2560 Arduino.
I need to connect 4 RFID readers. and read the cards from them.
This is my scheme: http://i.stack.imgur.com/huuiu.png
Im using the example code at the arduino: rfid/ReadUidMultiReader.ino at master · miguelbalboa/rfid · GitHub
ofcourse that I change the arrays to 4 cards.
when I put all of the cards on the Arduino it reads them all.
but, If I put less than 4 is not working!
Can someone help please with this code. thx!
You haven't posted any code.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 5
#define SS_1_PIN 22
#define SS_2_PIN 24
#define SS_2_PIN 26
#define SS_2_PIN 28
#define NR_OF_READERS 4
byte ssPins = {SS_1_PIN, SS_2_PIN, SS_3_PIN, SS_4_PIN};
MFRC522 mfrc522[NR_OF_READERS]; // Create MFRC522 instance.
  • Initialize.
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
for (uint8_t reader = 0; reader < NR_OF_READERS; reader++) {
mfrc522[reader].PCD_Init(ssPins[reader], RST_PIN); // Init each MFRC522 card
Serial.print(F("Reader “));
Serial.print(reader);
Serial.print(F(”: "));
mfrc522[reader].PCD_DumpVersionToSerial();
  • Main loop.
// Look for new cards
if (mfrc522[reader].PICC_IsNewCardPresent() && mfrc522[reader].PICC_ReadCardSerial()) {
Serial.print(F(“Reader “));
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(”: Card UID:”));
dump_byte_array(mfrc522[reader].uid.uidByte, mfrc522[reader].uid.size);
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = mfrc522[reader].PICC_GetType(mfrc522[reader].uid.sak);
Serial.println(mfrc522[reader].PICC_GetTypeName(piccType));
// Halt PICC
mfrc522[reader].PICC_HaltA();
// Stop encryption on PCD
mfrc522[reader].PCD_StopCrypto1();
  • Helper routine to dump a byte array as hex values to Serial.
    void dump_byte_array(byte buffer, byte bufferSize) {
    for (byte i = 0; i < bufferSize; i++) {
    Serial.print(buffer < 0x10 ? " 0" : " ");
    _ Serial.print(buffer
    , HEX);
    _
    it works only if I put all of the cards on the readers, If I lay less than 4 its not working well.
Code tags would be nice - the forum software has mangled your code at the end.
What happens if you have fewer than four tags?
There is something not right about this
#define RST_PIN         5
#define SS_1_PIN        22
#define SS_2_PIN        24
#define SS_2_PIN        26
#define SS_2_PIN        28
Maybe that SS_2_PIN is just “staying” on pins 24 and 26 while it gets its mail on pin 28.
byte ssPins[] = {SS_1_PIN, SS_2_PIN, SS_3_PIN, SS_4_PIN};How does that even compile?
