So I have been working on a code to run four rotary encoders each with their own hex displays to unlock a door. Right now when I run the program I have all 4 of the Hex displays turn on but they all display just the first rotary encoder's value instead of each one being there own. If anyone can help me out it would be greatly appreciated, Thanks, my code is below.
/* Read Quadrature Encoder
Connect Encoder to Pins encoder0PinA, encoder0PinB, and +5V.
Sketch by max wolf / www.meso.net
v. 0.1 - very basic functions - mw 20061220
#include <Wire.h>
#include "Adafruit_GFX.h"
#include "Adafruit_LEDBackpack.h"
//matrix 1 int
Adafruit_7segment matrix = Adafruit_7segment();
int relay = 50;
int count = 0;
int value = 0;
int val;
int encoder0PinA = 3;
int encoder0PinB = 4;
int encoder0Pos = 0;
int encoder0PinALast = LOW;
int n = LOW;
//matrix 1 int ending
//matrix 2 int
Adafruit_7segment matrix2 = Adafruit_7segment();
int count2 = 0;
int value2 = 0;
int val2;
int encoder2PinA = 5;
int encoder2PinB = 6;
int encoder2Pos = 0;
int encoder2PinALast = LOW;
int n2 = LOW;
//matrix 2 int ending
//matrix 3 int
Adafruit_7segment matrix3 = Adafruit_7segment();
int count3 = 0;
int value3 = 0;
int val3;
int encoder3PinA = 7;
int encoder3PinB = 8;
int encoder3Pos = 0;
int encoder3PinALast = LOW;
int n3 = LOW;
//matrix 3 int ending
//matrix 4 int
Adafruit_7segment matrix4 = Adafruit_7segment();
int count4 = 0;
int value4 = 0;
int val4;
int encoder4PinA = 9;
int encoder4PinB = 10;
int encoder4Pos = 0;
int encoder4PinALast = LOW;
int n4 = LOW;
//matrix 4 int ending
//Matrix 1
matrix.begin(0x70);
Wire.begin();
pinMode (encoder0PinA, INPUT);
pinMode (encoder0PinB, INPUT);
pinMode (relay, OUTPUT);
digitalWrite(relay, LOW);
matrix.writeDigitNum(0, 0);
matrix.writeDigitNum(1, 0);
matrix.writeDigitNum(3, 0);
matrix.writeDigitNum(4, 0);
matrix.writeDisplay();
//matrix 1 end setup
//Matrix 2
matrix2.begin(0x71);
pinMode (encoder2PinA, INPUT);
pinMode (encoder2PinB, INPUT);
matrix2.writeDigitNum(0, 0);
matrix2.writeDigitNum(1, 0);
matrix2.writeDigitNum(3, 0);
matrix2.writeDigitNum(4, 0);
matrix2.writeDisplay();
//matrix 2 end setup
//Matrix 3
matrix3.begin(0x72);
pinMode (encoder3PinA, INPUT);
pinMode (encoder3PinB, INPUT);
matrix3.writeDigitNum(0, 0);
matrix3.writeDigitNum(1, 0);
matrix3.writeDigitNum(3, 0);
matrix3.writeDigitNum(4, 0);
matrix3.writeDisplay();
//matrix 3 end setup
//Matrix 4
matrix4.begin(0x73);
pinMode (encoder4PinA, INPUT);
pinMode (encoder4PinB, INPUT);
matrix4.writeDigitNum(0, 0);
matrix4.writeDigitNum(1, 0);
matrix4.writeDigitNum(3, 0);
matrix4.writeDigitNum(4, 0);
matrix4.writeDisplay();
//matrix 4 end setup
//Matrix 1
n = digitalRead(encoder0PinA);
if ((encoder0PinALast == LOW) && (n == HIGH)) {
if (digitalRead(encoder0PinB) == LOW) {
encoder0Pos--;
encoder0Pos++;
Serial.println ("POS1" + encoder0Pos*27);
value = encoder0Pos*27;
if(value == 4,995 and value2 == 2781 and value3 == 1971 and value4 == 8586){digitalWrite(relay, HIGH);}
else digitalWrite(relay, LOW);
if(value >= 7){
while (value > 0) {
int digit = value % 10;
count++;
switch(count){
case 1: matrix.writeDigitNum(4, digit); if(value < 10){
matrix.writeDigitNum(0, 0); matrix.writeDigitNum(1, 0); matrix.writeDigitNum(3, 0);
} break;
case 2: matrix.writeDigitNum(3, digit); if(value < 100){
} break;
case 3: matrix.writeDigitNum(1, digit); if(value < 1000){
}break;
case 4: matrix.writeDigitNum(0, digit); break;
default: matrix.writeDigitNum(0, 0); matrix.writeDigitNum(1, 0); matrix.writeDigitNum(3, 0); matrix.writeDigitNum(4, 0); break;
value /= 10;
else{
count = 0;
encoder0PinALast = n;
//Matrix 1 END
//Matrix 2
n2 = digitalRead(encoder2PinA);
if ((encoder2PinALast == LOW) && (n2 == HIGH)) {
if (digitalRead(encoder2PinB) == LOW) {
encoder2Pos--;
encoder2Pos++;
Serial.println ("POS2 " + encoder2Pos*27);
value2 = encoder2Pos*27;
if(value2 >= 7){
while (value2 > 0) {
int digit2 = value2 % 10;
count2++;
switch(count2){
case 1: matrix2.writeDigitNum(4, digit2); if(value2 < 10){
matrix2.writeDigitNum(0, 0); matrix2.writeDigitNum(1, 0); matrix2.writeDigitNum(3, 0);
} break;
case 2: matrix2.writeDigitNum(3, digit2); if(value2 < 100){
} break;
case 3: matrix2.writeDigitNum(1, digit2); if(value2 < 1000){
}break;
case 4: matrix2.writeDigitNum(0, digit2); break;
default: matrix2.writeDigitNum(0, 0); matrix2.writeDigitNum(1, 0); matrix2.writeDigitNum(3, 0); matrix2.writeDigitNum(4, 0); break;
value2 /= 10;
else{
count2 = 0;
encoder2PinALast = n2;
//Matrix 2 END
//Matrix 3
n = digitalRead(encoder3PinA);
if ((encoder3PinALast == LOW) && (n3 == HIGH)) {
if (digitalRead(encoder3PinB) == LOW) {
encoder3Pos--;
encoder3Pos++;
Serial.println ("POS3 " + encoder3Pos*27);
value3 = encoder3Pos*27;
if(value3 >= 7){
while (value3 > 0) {
int digit3 = value3 % 10;
count3++;
switch(count3){
case 1: matrix3.writeDigitNum(4, digit3); if(value3 < 10){
matrix3.writeDigitNum(0, 0); matrix3.writeDigitNum(1, 0); matrix3.writeDigitNum(3, 0);
} break;
case 2: matrix3.writeDigitNum(3, digit3); if(value3 < 100){
} break;
case 3: matrix3.writeDigitNum(1, digit3); if(value3 < 1000){
}break;
case 4: matrix3.writeDigitNum(0, digit3); break;
default: matrix3.writeDigitNum(0, 0); matrix3.writeDigitNum(1, 0); matrix3.writeDigitNum(3, 0); matrix3.writeDigitNum(4, 0); break;
value3 /= 10;
else{
count3 = 0;
encoder3PinALast = n3;
//Matrix 3 END
//Matrix 4
n4 = digitalRead(encoder4PinA);
if ((encoder4PinALast == LOW) && (n4 == HIGH)) {
if (digitalRead(encoder4PinB) == LOW) {
encoder4Pos--;
encoder4Pos++;
Serial.println ("POS4" + encoder4Pos*27);
value4 = encoder4Pos*27;
if(value4 >= 7){
while (value4 > 0) {
int digit4 = value4 % 10;
count4++;
switch(count4){
case 1: matrix4.writeDigitNum(4, digit4); if(value4 < 10){
matrix4.writeDigitNum(0, 0); matrix4.writeDigitNum(1, 0); matrix4.writeDigitNum(3, 0);
} break;
case 2: matrix.writeDigitNum(3, digit4); if(value4 < 100){
} break;
case 3: matrix4.writeDigitNum(1, digit4); if(value4 < 1000){
}break;
case 4: matrix4.writeDigitNum(0, digit4); break;
default: matrix4.writeDigitNum(0, 0); matrix4.writeDigitNum(1, 0); matrix4.writeDigitNum(3, 0); matrix4.writeDigitNum(4, 0); break;
value4 /= 10;
else{
count4 = 0;
encoder4PinALast = n4;
//Matrix 4 END
