Multiple sensor PCB?
We have an IoT setup at home that monitors lots of stuff and controls many things and it is all working fine on nRF24L01 for the past 3+ years. But, adding Nodes is cumbersome as I have to solder together a Nano, radio, sensors, Level-Shift etc as needed.
I am thinking of re-doing the entire thing with ESP8266/ESP32 boards and I found this board ( NodeMCU Breakout/Carrier/Dev Board Overview - YouTube ) which looks ideal but the NodeMCU board is no longer available from Amazon. I like this guy's approach as he has a spot for soldering in a Level-Shift.
Can anyone suggest a similar version of an ESP-style breakout and where to buy? I'd like to go with the ESP32 for the much improved Mesh Networking, but not critical.
I did quite a lot of searching but suspect I am not using the best search-terms. So, suggestions for those would help as an alternative.
Thanks
The NodeMCU board is being resold by Amazon, they are not the manufacturer. AliExpress and Ebay both have them for under $5.00 as well as many others. I used " NodeMCU board" as my search term. I logged into AliExpress and eBay and used the same term, all returned positive results.
gilshultz:
[/quote]
Thanks I am aware of that, but I only buy from Amazon these days.
It is the multiple sensor board I am after and not the NodeMCU. The guy I linked to also made a later version (Kube) but I cannot find any of the boards for sale.
The Kube or an alternative but similar PCB designed for the ESP32, is what I am after.
LazyOperator:
Quote from: LazyOperator Sun Nov 15 2020 15:43:41 GMT+0100 (Mitteleuropäische Normalzeit)
Then I don't understand your question...
