I have used:
- BMP280
- BMP390
- AHT20
- DS3231
- LPS22HB
- HS3001
Board used : Arduino Nano Ble Sense Rev 2
Connected everything using I2C protocol on breadboard.
Code is fine but I am facing issues with output of 3rd and 6th sensors.
#include <Arduino_LPS22HB.h>
#include <Arduino_HS300x.h>
#include <DS3231.h>
#include "Adafruit_BMP3XX.h"
#include <Adafruit_BMP280.h>
#include <Adafruit_AHTX0.h>
DS3231 rtc;
Adafruit_BMP3XX bmp390;
Adafruit_BMP280 bmp280;
Adafruit_AHTX0 aht;
while (!Serial) {
if (!BARO.begin()) {
Serial.println("Failed to initialize pressure sensor!");
while (1)
if (!HS300x.begin()) {
Serial.println("Failed to initialize humidity temperature sensor!");
while (1)
if (!bmp390.begin_I2C()) {
Serial.println("Could not find a valid BMP390 sensor!");
while (1)
if (!bmp280.begin()) {
Serial.println("Could not find a valid BMP280 sensor!");
while (1)
if (!aht.begin()) {
Serial.println("AHT20 is not connected!");
while (1)
sensors_event_t humidity, ahttemp;
aht.getEvent(&humidity, &ahttemp);
float temperature = BARO.readTemperature();
float HStemperature = HS300x.readTemperature();
float rtcTemp = rtc.getTemperature();
float bmp390Temp = bmp390.readTemperature();
float bmp280Temp = bmp280.readTemperature();
Serial.print("Baro temperature : ");
Serial.print(temperature);
Serial.print("°C");
Serial.print("HS300X temperature : ");
Serial.print(HStemperature);
Serial.print("°C");
Serial.print("RTC temperature : ");
Serial.print(rtcTemp);
Serial.print("°C");
Serial.print("BMP390 temperature : ");
Serial.print(bmp390Temp);
Serial.print("°C");
Serial.print("BMP280 temperature : ");
Serial.print(bmp280Temp);
Serial.print("°C");
Serial.print("AHT20 temperature : ");
Serial.print(ahttemp.temperature);
Serial.print("°C");
