Thinking of ways to go about a project. Not sure how much an uno can handle while keeping up with a bunch of sensors. The project is essentially building a full digital guage set for a vehicle.
Each sensor would have its own display. Thinking about those 4 digit tm1637 displays for most of them. . coolant temp display. Tachometer. . speedometer will be a custom display probably running the same driver chip only larger digits. Would be nice to add a odometer. I have a 7 digit led display from an ancient motorola mobile phone. Trip miles would be nice too.
Thinking about adding a clock/trip timer.
And digital fuel reading approximate gallons remaining from the fuel level sensor.
The speed, rpm, odometer would be the important things to keep up quickly. .
I may add a couple things although at this moment it would be nice to have some input/recommendations etc.
Coolant temp and fuel level would be interpreted from analog "voltage divider" type sensors. Since both are resistance based sensors. Tach would be gathered from the distributer tach output divided by 6? Being a v6 engine. Speedometer would be an infared sensor that is currently attached to the speed cable. Would have to convert the pulses to a MPH reading. Then how to make an odometer work from those same pulses from the infared sensor. (Sensor was used on cruise control equipped models)
Thoughts, tips, ideas welcomed. Anything that would help with this project. Boards libraries, sketches that would work better for this.
