Hi There,
I am a novice at Arduino, and get by at looking at others code and ‘hacking’ it to suit. Recently I have attempted to get multiple senors to write to a SD card. I managed to get the sensors being detected, and the RTC working, but when I add the code to about the SD setup in the VOID setup, I get a loop in the VOID loop.
The code below works fine without the SD card code in the void setup, but once added, it gets stuck at the //set time delay loop. Keeps returning Test point 1 & test point 2.
Any help appreciated
#include <OneWire.h>
#include "RTClib.h"
#include <Wire.h>
#include "SD.h"
File logfile;
RTC_DS1307 RTC;
char *names[] = {"Upper","Lower"};
// DS18S20 Temperature chip i/o
OneWire ds(12); // on pin 12
void setup(void) {
// initialize inputs/outputs
// start serial port
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.print("RTC is NOT running!");
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(10)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// create a new file
char filename[] = "LOGGER00.txt";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
logfile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (logfile) {
Serial.print("Writing to test.csv...");
logfile.println("SD card is working");
// close the file:
logfile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
int d_temp(byte data[12])
word TReading, Tc_100,SignBit;
TReading = (data[1] << 8) + data[0];
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
return Tc_100;
for (int z=0; z <= 2; z++){
byte i;
byte present = 0;
byte data[12];
byte addr[8];
word secs;
static int sensor=0;
if ( !ds.search(addr)) {
Serial.print("\n"); //No more
ds.reset_search();
Serial.println("Test point 1");
// Set time delay
for(secs=0; secs < 5; secs++)
delay(1000); // 1000 = 1sec
sensor = 0;
Serial.println("Test point 2");
return;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
if ( addr[0] == 0x10) {
Serial.print("Device is a DS18S20 family device.\n");
else if ( addr[0] == 0x28) {
int Whole, Fract;
int Tc_100;
Tc_100 = d_temp(data);
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if(sensor != 0)
Serial.print(", ");
if(sensor > sizeof(names)/sizeof(char *))
Serial.print("Sensor with no name");
Serial.print(names[sensor]);
Serial.print(" = ");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
sensor++; // Move on to the next sensor
else {
Serial.print("Device family is not recognized: 0x");
Serial.print("\n");
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
OneWire::crc8( data, 8);
if (z == 1){
DateTime now = RTC.now();
Serial.print(", ");
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
//Serial.println();
moderater: added code tags…please use them second icon from right
