multiple sensors on arduino uno
so for a school project am placing multiple detection sensors on an Arduino Uno. I need them to work separately but at the same time. I have the code for each sensor separately but no matter how hard I tried I can’t combine them into one sketch. please help.
pinMode(A0,INPUT);
pinMode(A1,OUTPUT);
pinMode(A2,OUTPUT);
pinMode(11,OUTPUT);
digitalWrite(A2,HIGH);
digitalWrite(A1,LOW);
Serial.println(analogRead(A0));
delay(0);
if(analogRead(A0) < 250)
digitalWrite(11,HIGH);
digitalWrite(11,LOW);
int Sensor = 2;     // RCWL-0516 Input Pin
int Pbut = 3;       // Push button Input Pin
int LED = 12;       // LED Output Pin
int sensorval = 0;  // RCWL-0516 Sensor Value
int pbval = 0;      // Push button value
  pinMode (Sensor, INPUT);  // RCWL-0516 as input
  pinMode (Pbut, INPUT);    // Push button as input
  pinMode (LED, OUTPUT);    // LED as OUTPUT
  digitalWrite(LED, LOW);   // Turn LED Off
void loop(){
  sensorval = digitalRead(Sensor);  // Read Sensor value
  pbval = digitalRead(Pbut);        // Read Push button value
  if (sensorval == HIGH) {
    digitalWrite(LED, HIGH);  // Turn LED On
  if (pbval == LOW) {
#define trigPin 10
#define echoPin 13
float duration, distance;
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  // Write a pulse to the HC-SR04 Trigger Pin
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Measure the response from the HC-SR04 Echo Pin
  duration = pulseIn(echoPin, HIGH);
  // Determine distance from duration
  // Use 343 metres per second as speed of sound
  distance = (duration / 2) * 0.0343;
  // Send results to Serial Monitor
  Serial.print("Distance = ");
  if (distance >= 400 || distance <= 2) {
     Serial.println("Out of range");
  else {
    Serial.print(distance);
    Serial.println(" cm");
sketch_radar_sensor_copy.zip (2.93 KB)
sketch_infra_red_sensor.zip (2.58 KB)
sketch_ultrasonic_sensor.zip (3.09 KB)
Please post your code, in code tags.
no matter how hard I tried I can't combine them into one sketch.
Post your best effort and explain the problems
Did you use delay() in the programs by any chance ?
yeah a multiple times.
ibra7383:
Then you might benefit from reading Using millis() for timing. A beginners guide, Several things at the same time and looking at the BlinkWithoutDelay example in the IDE.
