I am trying to use two programs as a single program on Arduino nano 33 IOT. One of them uses I2C protocol (Piezoelectric pump) and the other uses SPI protocol (Pressure sensor). There is no error in the program while compiling. But the pressure sensor output is not correct (there is no change in the pressure and just showing 0). The piezoelectric pump works fine. Please find the code below:
Any help would be of great and highly appreciated. Thanks.
#include <Wire.h>
#include <SPI.h>
#define Addr (0xF6>>1)
#define TASTER 3
#define LED 13
#define I2C_DEVICEID 0x00
#define I2C_POWERMODE 0x01
#define I2C_FREQUENCY 0x02
#define I2C_SHAPE 0x03
#define I2C_BOOST 0x04
#define I2C_PVOLTAGE 0x06
#define I2C_P1VOLTAGE 0x06
#define I2C_P2VOLTAGE 0x07
#define I2C_P3VOLTAGE 0x08
#define I2C_P4VOLTAGE 0x09
#define I2C_UPDATEVOLTAGE 0x0A
#define I2C_AUDIO 0x05
// pressure_sensor
int SlaveSel = 10; //Define slave select as 10
//Transfer Variables
float Output_max = 15099494;//for psi___counts(90% of 2^24 counts or 0xE6666)
float Output_min = 1677722;//for psicounts (10% of 224 counts or 0x19999A)
int P_max = 300;//for mmHg;
int P_min = 0;
int Byte1,Byte2,Byte3,Byte4;
float Pressure;
float Result;
unsigned long Output;
long x2;
long x1;
long x0;
int debounce = 0 ;
int mode = 0;
#define MODE_OFF 0
#define MODE_50 1
#define MODE_100 2
#define MODE_200 3
#define MODE_400 4
#define MODE_800 5
#define MODE_MAX 6
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
Wire.begin();
//Serial.println();
SPI.begin(); //Begin SPI protocol
pinMode(SlaveSel, OUTPUT); //Define pin 10 as an output
pinMode(LED, OUTPUT);
pinMode (TASTER,INPUT_PULLUP);
digitalWrite(SlaveSel, HIGH); //Pull Slave select line high
Wire.beginTransmission(Addr);
Wire.write(I2C_POWERMODE); // write address = 0x01
Wire.write(0x00); //Adress 0x01 = 0x01 (enable)
Wire.write(0x40); // Adress 0x02 = 0x40 (100Hz)
Wire.write(0x00); //Adress 0x03 = 0x00 (sine wave)
Wire.write(0x00); //Adress 0x04 = 0x00 (800KHz)
Wire.write(0x00); //Adress 0x05 = 0x00 (audio off)
Wire.write(0x1F); // Adress 0x06 = 0x00 (EL1)
Wire.write(0x1F); // Adress 0x07 = 0x00 (EL2)
Wire.write(0x1F); // Adress 0x08 = 0x00 (EL3)
Wire.write(0x1F); // Adress 0x09 = 0x00 (EL4)
Wire.write(0x01); // Adress 0x0A = 0x00 (update)
Wire.endTransmission();
// the loop routine runs over and over again forever:
if (digitalRead(TASTER)==LOW) {
if (!(debounce&0x01)) {
mode=(mode+1)%MODE_MAX;
switch (mode) {
case MODE_OFF:
Wire.write(I2C_POWERMODE); // start adress
Wire.write(0x00); // disable pumps
digitalWrite(LED,LOW);
case MODE_50:
Wire.write(0x01); // enable pumps
Wire.write(0x00); // frequency 50 Hz
digitalWrite(LED,HIGH);
case MODE_100:
Wire.write(I2C_FREQUENCY); // start adress
Wire.write(0x40); // 100 Hz
case MODE_200:
Wire.write(0x80); // 200 Hz
case MODE_400:
Wire.write(0xC0); // 400 Hz
case MODE_800:
Wire.write(0xFF); // 800 Hz
debounce|=0x01;
if (debounce&0x01) {
debounce&=~0x01;
SPI.beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0)); //Begin comm with sensor while using the SPI settings: 800kHz, MSB first, SPI mode 0
digitalWrite(SlaveSel, LOW); //Pull slave select pin low to start data transfer
Byte1 = SPI.transfer(0xAA);
delay(25);
Byte2 = SPI.transfer(0x00);
delay(25);
Byte3 = SPI.transfer(0x00);
delay(25);
Byte4 = SPI.transfer(0x00);
delay(25);
digitalWrite(SlaveSel, HIGH); //Pull slave select pin high to stop data transfer
SPI.endTransaction(); //End comms with sensor
x2 = (long)Byte2<<16;
x1 = (long)Byte3<<8;
x0 = (long)Byte4;
Output = x2 | x1 | x0;
// Transfer function
Result = Output*5.8/15099494;
Serial.print("mmHg");
Serial.println(Result);
delay(100);
