does anyone know how to send multiple types of serial data?
eg volts, speed, pressure
i need to be able to read four types of data that are all seperate and be able to distinguish between them
thanks
thanks
to send multiple
to read four types
Do you want to send data or read data? I.e., what direction is the data going, into the Arduino or out of the Arduino?
You can send and/or receive any kind of data you like, it's all just bytes being sent across a serial link. Those bytes can represent voltage, speed or pressure in any units you like. You can send in binary or ASCII form. If you could explain a little more clearly what you want to do, then people here will be able to help.
thanks for the response !
i am making a miniture dyno and want to send data(speed, pressure, volts , current) to and from arduino continuosly using serial.
i hope i have made ny self clear if there r any questions pleas do not hesitate to ask
thanks
I'm trying to get two different data types printed into some sort of text file. Can someone help me do that, preferably in the "Processing" data language?
M@
Also, for just collecting data from 2 sources at once, you might try here:
http://www.prophecyboy.com/itp/icm/multiple-serial-input-from-arduino-to-processing/
M@
