Unfortunately, I already knew these tuts, but i gave it another shot. Without success.
I post here the modified code of the ublox GPS example, which is working fine on Serial1, but as soon as I change to Serial3 it doesnt work.
Maybe someone can spot the problem
u-blox_GNSS.h
u-blox GNSS Arduino
Leonardo Bispo
Mar 03, 2019
https://github.com/ldab/u-blox_GNSS
Distributed as-is; no warranty is given.
#include <Arduino.h> // required before wiring_private.h
#include <Wire.h>
#include <wiring_private.h>
// Enable Serial debbug on Serial UART to see registers wrote
#define GNSS_DEBUG Serial
#include "ublox_GNSS.h"
Uart Serial3 (&sercom4, 5, 4, SERCOM_RX_PAD_3, UART_TX_PAD_2);
float lat, lon, acc;
fixType_t fix = NO_FIX;
#define gps (Serial3) //if this is Serial1 and I change the wiring accordingly everything works just fine
GNSS gnss( gps );
Serial.begin( 115200 );
pinPeripheral(4, PIO_SERCOM); // Assign pins 4 & 5 SERCOM functionality
pinPeripheral(5, PIO_SERCOM);
gps.begin( 9600 );
if( gnss.init( ) )
Serial.println("\nGNSS initialized.");
Serial.println("\nFailed to initialize GNSS module.");
// Get coordinates with minimum 100m accuracy;
Serial.println("Get location");
if ( gnss.getCoodinates(lon, lat, fix, acc, 100) == 0)
Serial.println("Failed to get coordinates, check signal, accuracy required or wiring");
Serial.println("\nHere you are, lon:" + String(lon, 7) +" lat:" + String(lat, 7));
Serial.println("calculated error: " + String(acc) + "m");
Serial.println("\nOr try the following link to see on google maps:");
Serial.println(String("https://www.google.com/maps/search/?api=1&query=") + String(lat,7) + "," + String(lon,7));
delay(50000);
The SAMD21 has six SERCOMs. On the MKR WiFi 1010, it looks like:
0: used for I2C (Could be UART if you don't use I2C)
1: used for SPI (Could be UART if you don't use SPI)
2: SPI to WiFi interface (not usable)
3: not currently used. Potentially provides UART on pin 0/1.
4: MAYBE UART on pins 4/5?
5: Serial1 UART on pins 13/14
Pin 0/1 are NOT connected to USB as they would be on an AVR; the SAMD21 has dedicated USB hardware.
In your attempt I don't see you creating a SERCOM4_Handler() function?
