multiple Serials as argument for methods
Hey everyone. I'm currently working on a project that uses pretty much Serials. My Arduino Micro reads Signals from 4 SoftwareSerials und prints their values to Serial and Serial1.
if(some conditions){
int i1 = Sensor01.read();
if(some more conditions){
int i2 = Sensor02.read();
if(some other conditions){
int i3 = Sensor03.read();
if(some more other conditions){
int i4 = Sensor04.read();
if(...){
Serial1.print("Sensor01:")
Serial1.print(i1, DEC)
Serial.print("Sensor01:")
Serial.print(i1, DEC)
Serial1.print("Sensor02:")
Serial1.print(i2, DEC)
Serial.print("Sensor02:")
Serial.print(i2, DEC)
Serial1.print("Sensor03:")
Serial1.print(i3, DEC)
Serial.print("Sensor03:")
Serial.print(i3, DEC)
Serial1.print("Sensor04:")
Serial1.print(i4, DEC)
Serial.print("Sensor04:")
Serial.print(i4, DEC)
I was trying to use a method like readStuffFromASoftwareSerial, assigning the SoftwareSerial as a parameter and a method printToSerial assigning either Serial or Serial1 as a parameter. But how should they look like? Which datatype should the method expect? Is it easier to transmit the Serials as an Array entry?
Thanks in advance for your help.
someReturnType readStuffFromASoftwareSerial(SoftwareSerial &someInstance)
   // Do stuff
   return someStuff;
Serial and Serial1 are instances of the HardwareSerial class, so the function would accept a reference (&) to a HardwareSerial instance.
