Multiple servo motor with using arduino code!
I'd like to use an arduino to control 2 servos. I have found a single servo motor code but i coudnt find it multiple servo code.
i tryin to make a 4 different angle (0, 90, 180, 360 dgrees) with one of servo motor and other servo is 8 different angles (0, 45, 90, 135, 180, 225, 270, 360 dgrees).
Please help me to make the code plesase.
this is the i made a sing servo motor code.
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott http://people.interaction-ivrea.it/m.rinott
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.write(10); // sets the servo position according to the scaled value
delay(1000); // waits for the servo to get there
myservo.write(90); // sets the servo position according to the scaled value
myservo.write(180); // sets the servo position according to the scaled value
myservo.write(360); // sets the servo position according to the scaled value
Standard hobby servos will not rotate more than 180 degrees (many will rotate a somewhat less than this)
What are you trying to make?
i tryin to make a toy for uni project.
do you know about any coding stuff?
connects to the 2 servos into arduino
if you need 360 degree rotation then you may be better of using a stepper motor.
Can you describe what you want this toy to do?
Really? Did you look in the Playground?
hi God members, i am doing same project with him. And we want 1 servo to spin at random angles (0,45, 90,135,180) for 1-4s, and another servo to spin at (0,45,90,135,180)
