Multiple Servos and Knobs
Hello there,
I'm kinda new to Arduino and I'm struggling a bit so I hope that someone can help me out. For my project I want my servo motors to be controlled by several knobs individually. So far I've managed to make 3 servos move simalteniously with just 1 knob but not 3 knobs for 3 servos. I hope that someone can help me out.
Thank you!
Yannick
So far, you've not managed to post any code.
Can't find the door?
Some multi servo/pot test code you might try.
//zoomkat multi pot/servo test 3-23-13
//includes dead band for testing and limit servo hunting
//view output using the serial monitor
#include <Servo.h>
Servo myservo1;  //declare servos
Servo myservo2;
Servo myservo3;
Servo myservo4;
Servo myservo5;
int potpin1 = 0;  //analog input pin A0
int potpin2 = 1;
int potpin3 = 2;
int potpin4 = 3;
int potpin5 = 4;
int newval1, oldval1;  //pot input values
int newval2, oldval2;
int newval3, oldval3;
int newval4, oldval4;
int newval5, oldval5;
  myservo1.attach(2);
  myservo2.attach(3);
  myservo3.attach(4);
  myservo4.attach(5);
  myservo5.attach(6);
  Serial.println("testing multi pot servo");
  newval1 = analogRead(potpin1);
  newval1 = map(newval1, 0, 1023, 0, 179);
  if (newval1 < (oldval1-2) || newval1 > (oldval1+2)){ //dead band
    myservo1.write(newval1); //position the servo
    Serial.print(newval1); //print the new value for testing
    Serial.print("a,");
    oldval1=newval1; //set the current old value
  newval2 = analogRead(potpin2);
  newval2 = map(newval2, 0, 1023, 0, 179);
  if (newval2 < (oldval2-2) || newval2 > (oldval2+2)){
    myservo2.write(newval2);
    Serial.print(newval2);
    Serial.print("b,");
    oldval2=newval2;
  newval3 = analogRead(potpin3);
  newval3 = map(newval3, 0, 1023, 0, 179);
  if (newval1 < (oldval3-2) || newval3 > (oldval3+2)){
    myservo3.write(newval3);
    Serial.print(newval3);
    Serial.print("c,");
    oldval3=newval3;
  newval4 = analogRead(potpin4);
  newval4 = map(newval4, 0, 1023, 0, 179);
  if (newval4 < (oldval4-2) || newval4 > (oldval4+2)){
    myservo1.write(newval4);
    Serial.print(newval4);
    Serial.print("d,");
    oldval4=newval4;
  newval5 = analogRead(potpin5);
  newval5 = map(newval5, 0, 1023, 0, 179);
  if (newval5 < (oldval5-2) || newval5 > (oldval5+2)){
    myservo5.write(newval5);
    Serial.print(newval5);
    Serial.print("e,");
    oldval5=newval5;
  delay(50);  //to slow loop for testing, adjust as needed
